Tried charging the battery but it did not appear the battery was charging. Mistakenly put the battery pack back on the scooter and now cannot remove it, this is a 4-wheel scoter with a brand name GoGo.
This battery box attaches to the base platform with some very aggressive Velcro. The bottom of the box has a battery connector that mates up to the platform when the box is put on the scooter. The easiest method is to pull straight up on the battery box using the handle of the box. You will feel the Velcro release. Use 2 hands and wiggle it slightly. Some earlier versions had a battery box that actually locked into the base. This battery box required pulling out the flat release levers on both vertical sides of the box to release the battery box. I am going from memory on this.
If you need another technique, try removing the seat first and stand straight over the battery box. Bending your knees and grabbing with both hands pull the battery box handle straight up. It should release.
Before reinstalling vacuum and clean the platform and bottom of the box so that dirt is not keeping the surfaces from sliding easily.
Hope this helps.
SOURCE: Scooter has full charge but still won't go.
It probably means that the connections or wiring from your battery are loose or broken. When you add the extra current required to run the motors, the voltage is being lost. Monitor the battery voltage with a meter while trying to drive the scooter will prove this.
SOURCE: PRIDE GOGO 3 WHEEL MOBILITY SCOOTER NOT USED FOR 3
sounds to me like the power controller pot located on the handlebar lever that you use to go forward and reverse ? , is there any up and down movement with this lever , if so that will be causing intermittant power delivery.
SOURCE: The scooter rar wheels locked up nothing moves
hi, if the freewheel lever is jammed which is located on the drive motor, take the rear cover off and make sure the lever is not bent,
you will see how the freewheel lever is mounted under normally a rubber cover on the side of the electric motor ,
Let me know
SOURCE: Pride Legend scooter won't hold charge
check the wiring from the batteries as a wire could have come loose.
Regards
GeWiz
