SOURCE: LG Refrigerator LRBC22544st
If it was.. ICE.. NOT frost... Dont think it was a defrost problem, I read on hear somewhere about LGs having a problem with warm air leakage that maybe causing your problem.. i will see if i can find that post for you
Take off the back panel and cut the insullation as in the photo and this will never happen again. What happens is the water gets trapped and then ice forms and builds up and causes the blockage.
Sgt 48
The problem persist..
I tested the Fan Freezer is ok.
I tested the resistor is ok.
The evaparator coil is completly clean.....
When I connected to the AC, start running ok. up to more or less 3 min, then go to ERR FF, and keep this status permanently. Then I unplug from AC and plug again, start display ok, then after few minute go and go fo ERR FF, any command not respond........
So, please foward me to another posible fixing......
Regards,
Carlos Batista
-Definetly, the problem RR FF is a desing problem on this FRID model..
I unplug the unit for a least 8 hour and the frid become good, Now after 2 week working now present RR FS.
I'll do the same disconect and clean of ice and restart again, but I have now a question:
What it's the recommended tempreterature setting for freeze and refrigitator on tropical whether enviroment?
