Question about Roper RT18DKXKQ / RT18DKXKT Top Freezer Refrigerator
How to remove the terminal cover from Roper r18
How to locate fuse in Roper microwave model No. MHE14XKB
After removing the cover (most microwaves use security screws) the fuse will be on the circuit board near where the power cord connects. It will look like a glass fuse but is made of ceramic. Most have pigtail leads and are soldered directly to the board. Do not ever operate a microwave with the cover off.
Aug 18, 2016 | Roper Microwave Ovens
Roper washing machine will spin and rinse, will not pump water out or spin, is there a reset for it??
Check your exit hose spigot, it may be clogged. This is if your filter is all clean. There should be air for passage in the standpipe behind. Your hose should not fit airtight into the standpipe and neither too deep into it. Snaking out your standpipe would be good too.
Coming the second aspect if the above gives no result:
Perhaps you need new carbons brushes for the motor. It is a fairly straightforward repair. Remove the top cover, screws at rear, and slide top cover off towards the rear. The motor is located at the top right right rear, you will see the drive belt. Slacken the bolt that holds the motor, and push the motor down towards the top of the drum. You will see the 2 brush holders, they will be either black or white, pull the wires off the holder terminals, and depress the plastic lug that holds the brushes in place, slide the brushes out of the motor. The length of the brush should be at least half an inch long or replace. Fit new genuine carbon brushes, and follow instructions on packaging. Push the leads back on to the carbon terminals. tighten up motor, and make sure the belt is reasonably tight. Test on final spin before you refit top cover.
(Spares can easily be located on this very site - Fixya)
There are very gud videos on YouTube to guide you.
If helped pl click so.
Feb 26, 2013 | Roper RAS8445KQ Top Load Washer
My refrigerator is plugged up to the wall but not cooling or freezing
Hi, You may have defective compressor / motor or thermostat. Please check it out.
Jan 23, 2011 | Roper RS22AQXKQ Side by Side Refrigerator
My plug for my wall is a 4 prong outlet but the dryer is a three prong plug. The cable to by is a 4 prong plug but the back attachemnet only has three slots for the cable to plug into. What do I need to...
The 4 wire cord will connect as follows.
Red and Black wires connect to the 2 outside terminals on the back of the dryer.
The White wire connects to the center terminal.
The Green wire connects to the grounding screw just outside the terminal cover on the rear of the machine.
Sep 13, 2010 | Roper REX4634KQ Electric Dryer
My roper frig it has water inside under the vegie
clogged freezer drain in freezer. remove cover and work some hot water in and out of the drain with a turkey baster until water runs thru and then poutr more water thru drain until all ice is washed thru. good luck.
Jan 20, 2010 | Roper RT21AKXKQ Top Freezer Refrigerator
Dryer cord
Your four prong cord has 4 wires. Black,Red,Green and White.
Remove the 3 prong cord from the dryer.
The Black and Red wires go to the outside terminals on the dryer. The White wire goes top the center terminal. The Green wire goes outside the terminal cover to any nearby screw for grounding.
Jan 03, 2010 | Roper REX4634KQ Electric Dryer
Roper Dryer
Changing from 3 to 4 wire hookup on a electric dryer:
Power cord help for 3 & 4 prong dryer cords
This is an example of a three wire connection dryer cord hookup. Notice that there is a ground strap connected from the common center terminal to the frame of the terminal block. Place the center wire of the cord on the center terminal [ one with the ground ******** it ] and the other two wires will be placed on the outer terminals and it doesn't matter which wire goes right or left. Get the center wire of the cord right and you are in business.
This is an example of the 4 wire dryer cord hookup. Notice that the ground strap has been removed from the terminal block frame and folded back onto the center terminal for storage. You can see the colors of the other hookups. TIP: White always to the middle.
Mar 02, 2009 | Roper Dryers
Prongs on dryer
Take old cord off. Remove wire or ground strap connecting dyer frame to center (nutral) terminal. White wire goes to center terminal. Green wire to frame (ground) Red and Black wires go to two remaining terminal, order really won't matter.
Sep 28, 2008 | Whirlpool LER5636P Electric Dryer
Not receiving faxes
R18 means that your memory is full. Very strange. Go into the user box, file document, system user box, memory rx to delete all of the old faxes. This worked for me.
Aug 07, 2008 | Konica Minolta bizhub C250 All-In-One...
Roper Dryer
i have the same dryer it runs but doesnt heat and the timer wont move. its only 3 yrs old
Nov 28, 2007 | Roper REX3614KW Electric Dryer
Roper RT18DKXKQ / RT18DKXKT Top Freezer Refrigerator Logo
26 people viewed this question
Top Roper Refrigerators Experts
John Tripp
John Tripp
Bruce Denton
Gil Shultz
Are you a Roper Refrigerator Expert? Answer questions, earn points and help others
