Fossil PH1098 Starck Digital Watch - Black/Red FSL-PH1098 Logo
A
Anonymous Posted on Apr 06, 2014
Do I have to reset the Starck Ph-1098 after I change the battery
5 Related Answers
diarmaidok
  • 4 Answers
  • Posted on Dec 02, 2008
SOURCE: philippe starck ph-1071
hold the left, bottom button (marked ....) for a few seconds....then press the top right button (marked with 1 dot) to change between the hour, minute, date etc. use the bottom right button to advance the flashing number, and when finished setting time and date, use the bottom left button to stop the numbers flashing and return the watch to normal. hope this helps,
diarmaidok
  • 4 Answers
SOURCE: philippe starck with fossil ph-2006
hold the left, bottom button (marked ....) for a few seconds....then press the top right button (marked with 1 dot) to change between the hour, minute, date etc. use the bottom right button to advance the flashing number, and when finished setting time and date, use the bottom left button to stop the numbers flashing and return the watch to normal. hope this helps, this is also how to change the date for the other question asker (works on 2 other starck/fossil watches i have and i assume the controls are the same).
escapement
Arturs Kalnins
  • 2338 Answers
  • Posted on Dec 17, 2008
SOURCE: Can't set the time or adjust the ******** crystal Starck PH-1100
Take a VERY close look at yor watch and you should notice a few tiny buttons. One of them should correspond to MODE, another to SET and so on- depends on how many your watch has.
Use a pin or a needle to push them and find out the settings procedure.
If you cant find buttons on the case sides, examine case back. They can be hidden between the lugs, so, the strap should be taken off.
Remember- there are no watches in existance without adjustment features. Even atomic clock needs to be adjusted after a few million years of work:))
Good luck.
Arthur
escapement
Arturs Kalnins
  • 2338 Answers
  • Posted on Jul 29, 2009
SOURCE: starck watch PH 1071 110504. I just need to
try this link to get help;
http://www.fossil.co.uk/webapp/wcs/stores/servlet/ContentView?langId=10&storeId=32553&catalogId=20002&page=instructions
Rate, please.
Anonymous
  • 3 Answers
  • Posted on Feb 04, 2011
SOURCE: what battery does a Fossil Starck PH-1006 watch
Hi. I´ve got a ph-1030 and it works with a `RENATA 350`. I couldn`t d this reference so I bought a similar one.I got the `SR1130W` . This battery works but you have to place an small tape on the back (negative pole), to insolate the battery. You have to do it because this battery is a litle bite smaller than the renata 350. If you need anything else email to [email protected]
Manuel for Starck watch PH 1045
Look for a manual as a pdf on the web/internet
4answers
Philippe starck with fossil ph-2006
Fossil Contact Information Main support number 1-800-842-8621
Email support [email protected]
hope this helps
3helpful
What battery does a Fossil Starck PH-1006 watch take?
27helpful
How to change the greeting text in philippe starck watch PH 1116
press the mode button twice. that will change to date mode. during the date mode display ,hold set for 5 seconds. mission accomplished!
Nov 01, 2010 • Watches
1helpful
Starck watch PH 1071 110504. I just need to chance the time but I can't.
Rate, please.
3helpful
Philippe starck ph-1071
Top Fossil Watches Experts
john h
k24674
ADMIN Andrew
ADMIN Andrew
Are you a Fossil Watch Expert? Answer questions, earn points and help others
