The washer is not draining the water it leaves about 2 inches of water
SOURCE: directions on stacking dryer on washer
get a stacking kit from your local appliance strore that sells frigidaire. they ARE EASY TO STACK WITH THE KIT.
SOURCE: Frigidaire Gallery Front-loading Dryer Stops Tumbling
I have a stacking Frigidaire washer/dryer. The dryer will not start at all.
Thanks for any info you can offer.
SOURCE: need new washer to stack on my dryer!
measure your dryer carefully and check with the dealer where you wish to purchase a machine, regarding
the stacking kit. It may work. They are general standard sized. Don't ry to gerry rig anything or you may have big problems. In your case I recommend using a well known SMALL appliance store that does theri own installations, so they will bring what they may need, but if yours works, they can still use it.Good Luck
SOURCE: Frigidaire Top Load Washer
Hello vohra_sam
welcome
You said , Water will not drain out
Usually this is the answer
Water in washer does not
drain or drains slowly.
Because drain hose is kinked or clogged.Clean and straighten the drain hose.
let me know, Huuum
SOURCE: frigidaire washer model FWX833AS1 top load
Hello Lcl2610.
welcome to Fixya,
My name is Huuum,
How old is your machine?
I have found some reasons of what may be the matter!
List of thinks to check
1.Defective Lid Switch
Check lid switch for proper operation. Check the switch for continuity. If it is found to be open, replace the switch assembly.
2.Faulty Direct Drive Coupling
The
Direct Drive (motor) Coupling may be broken. Many Whirlpool/Kenmore
brands washing machines utilize a small, relatively inexpensive direct
drive motor coupling. It's plastic and rubber and is mounted to the
shaft of the motor on one side, and to the transmission on the other.
It can wear out over time or fail under overloading conditions. This protects your transmission from excessive loading.
3. Faulty Water Level Switch
If the water level
switch is not resetting once the water is drain, power will not be
available to operate the motor during spin. Check the water level
4.Will not drain and displays F/02
The error code F/02 will
be displayed if the drain time exceeds 8 minutes. Press pause/cancel
twice to remove display. Check the pump filter and wiring connections
on the pump. If all looks good, replace the pump.
You may want to use a pro, rather than attempt this project your self.
Let me know how it goes!
Thank you Huuum.
Please remember to leave a rating
