I just put new topend kit in bike ran before can you give me specs to coil and pu coil and cdi box
If it ran before, I would double check your electrical connections. Its more likely you didn't get a connector pushed all the way together or left off a ground wire. The ignition coil specs are generally 1 ohm or less on the primary (small Wire) side, and 5K-10K ohms on the secondary (spark plug) side. Each side should be tested to ground. Pick-up coils are typically open or really large ohm reading in Megaohms normally and around 100 ohms when the magnet on the flywheel passes by. there is no way to test the CDI box other than putting it on a know running bike or getting a known good CDI and putting it on your bike. Double check that the spark plug cap is secured to the high tension lead as well. Testing the stator is a little more complicated, but a quick way is to close the gap on an old spark plug to about 0.010" and see if there is a week spark. If so, the stator will need to be replaced.
