Casio FX82MS Scientific Calculator Logo
A
Anonymous Posted on Apr 04, 2014
How to calculate x - Casio FX82MS Scientific Calculator
k24674
Level 3:
  • Casio Master 8,093 Answers
  • Posted on May 22, 2018
k24674
Casio Master
Level 3:
Answers
8093
Questions
0
Helped
4674893
Points
21596
Very Good Question. X could be anything.
2answers
How to calculate square feet
Assume you have a rectangular area such as a room and, for example, you want to calculate the square footage area for flooring or carpet. The way to calculate a rectangular area is by measuring the length and width of your area then multiplying those two numbers together to get the area in feet squared (ft2).
Square Footage Calculator - Calculator Soup
https://www.calculatorsoup.com/calculators/construction/square-footage-calculator.php.
or try this link.
How to calculate square feet Google Search
3answers
How do I reset to just basic adding
Dont know what you are saying.
Basically turn it off and on if your stuck.
3answers
Where is the combination button on SHARP EL-501W calculator?
There is no such key on this calculator. You can calculate it using factorials. To calculate nCr you can calculate n! / (r! * (n-r)!).
How to use the log fucntion
To calculate the natural logarithm of a number, enter the number and press the LN key. To calculate the natural logarithm of a calculated result, simply press the LN key.
To calculate the natural logarithm of 3, press 3 LN
To calculate the logarithm to any other base, calculate the natural logarithm and then divide by the natural logarithm of the base.
To calculate the base-10 logarithm of 3, press 3 LN / 1 0 LN =
1helpful
How to calculate 17^23mod55 in casio scientific calculator fx-991MS?
Using the Windows calculator in scientific view, we get:
17^23 = 19,967,568,900,859,523,802,559,065,713
which is 29 digits long, ie much longer than the capacity of most calculators.
Because both 17 and 23 are prime numbers, it isn't possible to simplify this calculation, so you will need to use find a calculator that has sufficient capacity to be able to handle numbers of this length.
The xnumbers add-in for Microsoft Excel can also be useful for this sort of calculation (do an internet search for it).
Using the Windows calculator, MOD55 of the above number is 18.
1helpful
MS-80TV AUTOMATICALLY ROUNDS UP TO 1 DECIMAL DIGIT
The [MODE] key can be used to select the modes described below.
Important! The following is a general explanation of Scientific Calculator modes. Note that your calculator may not include all of the modes described here.
1) Calculation Modes
Before performing a calculation, you first need to select the appropriate calculation mode.
COMP: Basic arithmetric calculations
(arithmetic operations, trigonometric functions, etc.)
COMPLEX: Complex number calculations
SD: Single-variable statistical calculations
(sample standard deviation, etc.)
LR or REG: Paired-variable statistical calculations
(linear regression statistical calculations, etc.)
BASE or BASE-n: Binary, octal, decimal, hexadecimal number system calculations
MAT: Matrix calculations (determinants, etc.)
VCT: Vector calculations
EQU: nth degree equations, simultaneous equations
2) Display Settings
Use these settings to control how calculation results are displayed.
Note that changing the Fix and Sci settings does not affect internal calculation results.
Norm: Exponential display format and cancels the currently configured Fix and Sci settings.
Fix: Specifies a fixed number of digits to the right of the decimal place.
Sci: Specifies a fixed number of significant digits.
3) Angle Unit Setting
(90°=?/2 radians=100 grads)
Deg: Degrees
Rad: Radians
Gra: Grads
4) Engineering Mode
Use this mode when you want to input and perform calculations using engineering symbols.
Please rate this response . .
2answers
Who Repairs them?
calculators are repaired in watch works...they will give u a better service for calculators...if it s scientific calculators..then giv it to the computer service providers....but usually there s very few service providers can been seen for repairing the calculators...since it doesnt cost much!!!!
Top Casio Office Equipment & Supplies Experts
k24674
Arnie Burke
Arnie Burke
Ngoro
Are you a Casio Office Equipment and Supply Expert? Answer questions, earn points and help others
