When turning to wash cycle, lights blink simutaniously along with start button and door doesnt seem to be going into lock mode
SOURCE: Bosch Nexxt 100 series washer wfmc1001uc
According to the manual, you have to:
1. Turn program selector to "off"
2. Turn selector to Drain or Spin
3. Press the start / pause
Wait until program ends.
Open door.
or
Press "start / pause" until the start / pause light flashes.
SOURCE: door won't open Bosch Nexxt 100 Series WFMC1001UC Front Load Washer
The door sensor/ lock is not working well
SOURCE: i have a bosch nexxt 100 series washer during the
I am not a repair professional. I am a 78 year old man who has been making his own repairs for about 50 years. So the washer or dryer ID doesn't mean much to me. I came to fixya looking for a schematic for an really old AM/FM radio and just happened to see that more than 4,700 people were asking for help with a washer repair. I recently had a washer repair of my own and at that time I found an excellent video which showed me how to take my machine apart. This video made it possible for me to do my own repair. If you are repairing a dryer, a front load washer, or a dishwasher, I suggest you
go directly to www.applianceaid.com where they have very good step by step trouble shooting and repair information on both washers and dryers as well as many other appliances. If you have a direct drive top load washer and need help taking it apart this video is an early christmas present. I was so impressed with it that when I saw all these people needing help, I wanted to tell them about it. If you look at the back of your washer and the panel is solid (no small inspection plate to remove which would indicate you have a v-belt drive) chances are you have a direct drive and this video is just what you need. You can see it at www.acmehowto.com You will probably still need help in determining what the trouble is and how to fix it. After viewing the video or if you have a v-belt drive rather than a direct drive, I suggest you go to www.applianceaid.com where they have very good trouble shooting and repair nformation on most washers and dryers, dishwashers and many other household appliances. I think you'll find what you need there. Don't worry about the timer on a washer, they hardly ever go bad. I realize I haven't solved your problem for you, but I hope I have sent you to a place that will help you solve the problem. Good luck with it.
SOURCE: Bosch Nexxt 100 series front load washer
You first of all need to check the pump filter.
This should be located at the botom front right of washer.
Look for a drop down flap or cover, once located, unscrew filter anti-clockwise to remove and clean.
The pump itself is directly behind the filter housing, check there is nothing stuck in the housing.
This should solve the prob.
Please leave feedback for my solution.
Thankyou.
Testimonial: "I submitted a question and got a very quick response. The response was useful and enabled me to make the repair myself. Thank-you!"
SOURCE: Bosch Nexxt 100 series washer stops at 1st spin cycle
take a look at your manual that came with your machine go to problems usually at the back and see what that says,or go to the bosch website and type in your model number its on the inside of the door.i would suspect a program fault.adrian,,,,,
Turn program selector to "off". Turn
selector to Drain or Spin. Press the start / pause. Wait until program ends. Open door.
OR
OR
First, unplug the machine and turn off the water supply. On the lower
right of the front panel is a 6" / 15mm cover. Near the bottom of this cover
is a small hole. Insert a piece of wire into this hole, and push in gently.
While pushing, turn the cover clockwise,
it will came off.
The door release is a narrow white plastic strip
hanging down on the right; Pull down on this strip while pushing in on the
door, the door lock will release.
Pl click if helped
Make sure dial is switched
to 'off'. Unplug your machine, then plug
it back in. Hold down the rinse and delay buttons with one hand. With the other
hand, switch the dial from off to cold or warm or whatever cycle you want. All the buttons flash a few times, then just
the start button flashes. If if doesn't work, do it again.
To get the clothes out if
you are having trouble, open door manually. Near the bottom of this cover is a small
hole. Insert a piece of wire into this hole, and push in gently. While pushing,
turn the cover clockwise, it will came off. The door release is a narrow white plastic
strip hanging down on the right; Pull down on this strip while pushing in on
the door, the door lock will release.
Click helped if helped.
