SOURCE: how to run diagnostic on frigidaire affinity ATF6000ES front load washer
Hello Tony bent - What issue is the unit experiencing exactly? Can you tell me if it is displaying any specific error codes? If I know more information on what the issue is, I can try to better assist you further.
SOURCE: error code DR comes up on my Frigidaire Affinity and won't keep running
It is telling you there is something wrong with the door lock assembly. You will probably have to replace it, but check it first for a broken wire or some other problem that you can fix.
Here is a link to the part if you need it.
Here is a link to a service manual for your machine that will take you through the testing and repair process.
http://www.emaservicetips.com/pdfs/778_5995456851_Affinity_washer.pdf
