SOURCE: How to copy VCR tape
Did it come with a manual? I would recommend reading it. If you don't have a manual I would order one from Toshiba. If it is anything like my DVD/Video recorder you just put the tape and DVD in and hit the "Dubbing" button. You can not copy Macrovision recorded tapes.
SOURCE: Connecting TV to DVD / VCR Recorder
Appreciate the direct "Ask Me".
I am assuming that what you intend to do is:
Yes, but only if you are not using/needing a cable decoder box. To do this, the coaxial cable from your provider would have to be made to supply both the RF/ANT/CABLE IN of the VCR/DVD and the TV. To accomplish this, you would need a 2-way splitter. One input to the splitter, 2 outputs, one each for the DVD/VCR and the TV. The DVD/VCR would have to be connected to the TV using yellow, white & red RCA cables. To watch DVD, VCR and/or what is being recorded on the DVD/VCR, set the TV to Video mode. To watch regular TV, select the channels on the TV.
Good luck and Thank you for using FixYa.
Pls be informed that due to my current rank and rating, even a Helpful wouldbe detrimental to my status. Should this solution not address yourconcern, it would be appreciated if you could just not rate it at all. Cheers.
SOURCE: dvd/vcr recorder stops recording
DVD-RAM itself, and DVD-R formatted in "VR" mode are SUPPOSED to allow for recording "ONE TIME" per DRMA. The broadcasters are probably sending the wrong copy protection signal if the -RAM & -R/VRmode are stopping.
At least, that is my understanding.
tom
SOURCE: need remote control for LG dvd/vcr recorder..misplaced code sheet
Code numbers of controllable TVs
If more than one code number is listed, try entering
them one at a time until you find the one that works
with your TV.
Manufacturer Code Number
LG / GoldStar 1 (Default), 2
Zenith 1, 3, 4
Samsung 6, 7
Sony 8, 9
Hitachi 4
SOURCE: can I copy vcr tapes with the LG RH 1999H dvd/hdd recorder?
I use the av2 input in the front of the recorder to copy my vcr tapes to the hard drive
