After switching off and on at the mains last night the volume and mute on stopped responding on Humax remote. IT is PVR9150T and remote RT531B. TV Remote works fine with volume. Humax remote works fine on all except volume and mute. The green volume bar appears and moves but no change in the sound. Anyone help is it Humax remote or TV?. What to do please any suggestions
SOURCE: i have a crappy HP
It's acting like the juice is drained in the battery. Are you sure it's charged? Do you have a spare battery you can swap out?
Some of them come with two. I actually have the same series laptop (a Pavilion dv6258se, 6000 series), and they can be a little flaky.
I also had an issue where my HP power cable (that connects the laptop to the wall outlet) was faulty, and needed to be replaced, because it stopped charging the battery. I ended up purchasing a generic replacement power cable on eBay.
SOURCE: Sound gone after Updates Downloaded on Vista
hmmm...its better to reinstall sound driver may be sound dll are courpt during updating a windows...reinstall the sound driver then sound will come
SOURCE: direct receiver is not responding to remote
if you go to: http://www.directv.com/DTVAPP/global/contentPageIF.jsp?assetId=P4380052#h:1020.450
it has different remote codes. you would have to select "satellite setop box" also you need the model # of the receiver which can be found (normally) behind a door on the front panel of the receiver on a sticker (where the access card and reset button are) if its not a directv receiver, (hughes, etc) then it would probably be on the back of the receiver you would see a sticker with the model # of this receiver.
the first code should be 00001 follow the instructions on how to program on that website.
SOURCE: Dell Wireless keboard model # RT7D40 not responding
You may need to press a button on the bottom of the keyboard or on the reciever portion to get it to reconnect. It will be a very small button, probably about an eighth of an inch, that appears level with the surface surrounding it. Use a straightened paper clip or ball point pen to press it. A pencil contains lead that could cause an electrical short between contacts, so don't use a pencil.
