SOURCE: Kenmore coldspot #59597993
Check the condenser where heat is removed from the system. Look under the front behind the toe plate under the door. Use a vacuum crevasse tool to get into the narrow places to draw out the dust and lint. Make sure the fan under the refrigerator is running. You can remove the bottom panel in back to observe the fan operation. Listen for sounds at the back like a hum and a click. Check the compressor to see if it is hot and running. If the compressor is cold you may have a control problem.
SOURCE: Freezer and fresh food compartment are warm.
The fridge thermostat is faulty and not cutting in
at the required temperature. Fridge stats are not easy to test, so the
best way is to bypass the stat to see if the compressor starts. To
bypass the stat first unplug the appliance and remove the stat housing
from inside the fridge compartment, once you have removed the housing
you will see the stat inside. Some stats have 2 terminals some have 3,
whatever yours has you will need to connect the compressor wire (
Black) to the live wire (Red or White). When you have bypassed the
stat plug the appliance back in and switch on, if the fridge starts up
and runs ok you will need to purchase a new stat.
Let freezer get down in temp and fridge should start chillg.Good luck
SOURCE: Kenmore refrigerator Freezer is cold but fresh food side is warm
Normal
0
MicrosoftInternetExplorer4
/* Style Definitions */
table.MsoNormalTable
{mso-style-name:"Table Normal";
mso-tstyle-rowband-size:0;
mso-tstyle-colband-size:0;
mso-style-noshow:yes;
mso-style-parent:"";
mso-padding-alt:0in 5.4pt 0in 5.4pt;
mso-para-margin:0in;
mso-para-margin-bottom:.0001pt;
mso-pagination:widow-orphan;
font-size:10.0pt;
font-family:"Times New Roman";
mso-fareast-font-family:"Times New Roman";}
The fridge gets its cold air from the freezer through a vent(damper)
between the freezer and fridge.The fan in the freezer blows air through it.
Make sure this fan is running. You may have to hold the door switch in for it
to run. There is a flap you adjust with
the fridge temp. control. Make sure it's opening and closing when you adjust
the fridge temp.
The problem could be the electronic control if
you have one or the mechanical linkages.
SOURCE: ice keeps building up on
The drain in the freezer behind back lower panel
needs opening. You can see it at the bottom of the back panel
underneath the evaporator coils. (The cold coils)
Run Hot water in the drain until it clears or use a hairdryer.
When the defrost melts the water it goes down the drain
If the drain is clogged with Ice or ? The defrost water
overflows into the ref. or freezer
Also check fan undernearh Ref in the rear
Clean condenser coils underneath
.I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
Thanks for using fixya
Leo Ponder
imufo2
Please VOTE FOR ME IF THIS WAS HELPFUL
It is quite common for a refrigerator to begin the first signs of a defrost problems once he fresh Food section begins to warm. Auto Dampers are an additional component to check while searching for the true reason for Fresh Food compartment warming. First look inside the freezer compartment and and see if there is a layer of frost building on the rear wall. If yes you will need to manually defrost unless you have anothr place to store the freezer goods. Unplug refrigerator and then remove the rear panel of freezer to get a good look at the snow covering your evaporator coils. Defrost with a hair drier. Now we need to look for the cause Auto Damper, Click here for the photo location of these parts=> MSD2756GEW Controls Section the adaptive defrost control is most likely the problem and is listed in the photo as location 13 and the auto damper
61005971 Damper Control Assembly
61005988 Adaptive Defrost Assembly
The Auto Damper model refrigerator has two controls and both have capillary sensing.
The Auto Damper controls the fresh food temperature and the Freezer Temperature
Control guides the freezer temperature. The fresh food compartment temperature is maintained by a damper assembly located at the back of the temperature control housing. Changes in air temperature cause the damper door to open and close. A control rod and gear connect the fresh
food control knob to the damper control.
Turning the fresh food control knob to the coldest position increases the flow of freezer air into the fresh food section. The freezer compartment temperature control warms at a faster rate and cools at a slower rate, increasing the compressor run time necessary to maintain a satisfied freezer temperature control.
Click Here=> Here is how to test a Maytag MSD2756GEW Auto Damper
There is always other possiilities but I see two other things that may cause this and that is the defrost heater with defrost Thermostat=> 61006199 Defrost Heater Assembly
I know this was long and possibly confusing but please ask if you should have questions or one on one assistance, Thanks, Sea Breeze
