KitchenAid Kitchen Aid Kitchenaid 5-speed Ultra Power Blender Blenders 5-Speed Blender Logo
A
Anonymous Posted on Apr 03, 2014
Oven will not heat up - KitchenAid Kitchen Aid Kitchenaid 5-speed Ultra Power Blender Blenders 5-Speed Blender
Ross Keen
Level 3:
  • KitchenAid Master 1,365 Answers
  • Posted on Jul 23, 2014
Ross Keen
KitchenAid Master
Level 3:
Answers
1365
Questions
0
Helped
583377
Points
2445
Kitchen Aid blenders are used for chopping/blending not heating.
Prolectrix Soup Maker. My soup maker didn't heat the soup up?
Question edited for clarity.
That is likely a failed heating element, failed thermostat, or worse case scenario, a failed control board.
https://www.google.com/search?q=prolectrix+soup+maker+not+heating+up
Feb 06, 2024 • Blenders
Does anyone have experience of the Russell Hobbs soup maker
It makes cold soups like Gazpacho and Vichyssoise, so make sure the heating / cooking function is set.
If it is, ask Russel Hobbs where your local service centre is to diagnose and replace the element.
https://www.google.com/search?q=Russell+Hobbs+soup+maker
Replacement parts?
You might try contacting the company direct - this is the company which owns nuwave
Hearthware Home Products
1795 Butterfield Road
Libertyville, IL 60048-1212
USA
888-287-0763 Toll Free
847-775-8123
M-F, 8:00A-4:30P CST
It will not continue to heat up
I have the same problem. Could you able to repair it
How to clean the oven on a cuisine 300
Call the manufactor or e-mail the company maybe they can give you another one.
How to use bamix to make bread dough
I have several recipes for bread both yeast and none. But not enough space here.
French Bread.
Use C blade. 3c plain flour.2Tbs rapid rise yeast. 3 Tbs sugar. 2Tbs salt
1c water. 2/3 c of milk. 3Tbs margarine or oil. heat together until 130F/55C add to yeast mixture and stir in with C blade add in an egg and stir.Empty onto a floured counter. Knead by hand for 8-10 mins cover and let rest for 10 mins.
Divide dough into 2, shape into loaves place on greased cookie sheet cover and let rise 15-30mins. Bak in a 400F/200C oven 18-20 mins until light brown,Remove cool and enjoy.
After starting the microwave, I get a "F-7" message on the display and it shuts down. What can I do to fix this? This is a whirlpool model # GH5184XPS-4.
hello,
what this error means indicate is as follow
The F-7 error code indicates that the water or oil (any liquid form) temperature sensor reading is out of range (below 23 degrees F or above 217 degrees F).
what you need to do to fix up your is to do general cleaning up on your oven both internal and external do this with care and allow it to dry up it self.
please when doing this you will have to put off any form of power supply connected to the oven .
thank you and thanks for using fixya.
Jun 01, 2010 • Blenders
Oven appears to remain on after the baking process is finished. It is a brand new Frigidaire double oven and we have just used it for the first time.
What is staying on? If you are hearing a fan staying on, don't worry about it. Some ovens have a cooling fan that continues to run until the oven cools down below a certain temperature.
Dec 22, 2009 • Blenders
My GE dryer was making some squeaking sound and now the heat does not work and clothes are not getting dry
Check the dryer dual-breakers in the house electrical panel--push off, then on. If no help, check for ~230 volts AC at the two slanted slots in the dryer power socket. If ok, the problem is likely the heating element(s) in back of the drum are burned out or the internal thermostat is open. To remove the drum, remove the top (push a thin putty knife rearward at each front corner to release latches) and then the front panel. The belt must be released (from inside the lower back) and the rear center screws of the drum removed. When the drum is removed, it gives access to the elements and temp control switches. Be sure to vacuum out all air passages and wash the lint filter in hot water and detergent to remove fabric softener deposits. Don't forget the air exit hose to the outside. Replace the belt on reassembly if heat damaged or badly worn. Hope this helps!
Nov 15, 2009 • Blenders
Top KitchenAid Blenders Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a KitchenAid Blender Expert? Answer questions, earn points and help others
