SOURCE: HYDRASTATIC TRANSMISSION DOESN'T MOVE
Far as I know the warranties are not transferable. Some hydrastatic transmission fluid can be checked by removing the battery and underneath there is a place to put the fluid and to check it. But not all models or makes gives you this option.
SOURCE: Husquavarna tractor battery won"t start engine
YOU NEED TO REPLACE THE SOLENOID IT IS SHORTING OUT AS TO THE GAUGE THEY WILL NEVER MOVE AS THE GENERATOR CHARGES ONLY WHEN THE BATTERY HITS 9 VOLTS THEN IT ACTIVATES TO CHARGE BACK TO 12 VOLTS BUT IN SMALL INCREMENTS
SOURCE: engine dies when clutch brake released on husqvarna gth2548
First check the seat switch,make sure it is plugged in tightly, these plugs have a safety tab built into them that will cut the engine off if you unhook it,sometimes the plug latch pulls out slightly and this will cut the engine, There are two other switches in the system one on the foot clutch and on on the mower clutch, if you follow the white wire from you ignition switch it will lead you to both of them,check those connections also.
SOURCE: just purchased Husqvarna YTH2348 Purged
As for whining sound I believe this normal. The purging instruction using the bypass valve ingaged on low engine running. Next with the bypass disengaged followed by the fwd with fast breaking and or rev with fast breaking actions to get the wheels to turning and getting better responce takes time. This does take some time to do - in my case 15 minutes or more. My tractor had 65 hours on it before it showed signs of not pulling a slight hill. I had to remove the transaxle and put in 50 wt. motor oil and with the purging I was able to bring new life back to this tractor. The original 30wt. motor oil is fine for a brake in oil and I did drain it and took the bottom cover pan off and cleaned the metal particals on the magnets and cleaned the filter. These transaxle are sealed but have a vent plug at the top of the case. That little plug is hard to get off with out damaging it. My tractor whins in forward and reverse but has good hydrostatic power now. So I say the whin is good!
SOURCE: hi i have a husqvarna ride on lawnmower that moves
sounds like your bely or one of the pulleys are wore out ck the pulleys and ck to see if the belt has sliped off the pulley
