SOURCE: We have a Bosch Axxis WTA 3510 electric dryer.
Remove the exhaust venting tubes and clean thoroughly. When lint builds up the moister sensor prevents the burner to 100 % hot causing thsi
SOURCE: I looked at the cylindrical fuses in the back and
Hi Thanks
for using FixYa. No Heat
issue in an electric dryer is usually caused due to three things mainly:
Thermal Fuse, Wiring Harness and/or Heating Element. Start with checking the
Thermal Fuse which is mounted inside the back cover panel to the exhaust duct
and is mounted in white plastic housing. If that's fine then the Heating
Element should be checked. Please do accept the solution if the
issue is resolved or post a comment for further assistance. Thanks Rylee
