When I start scanning on the scanner it reads lo and found and stops scanning. How do I get rid of the lo found?
SOURCE: i have a uniden bc72xlt hand scanner and after it
It sounds like you are in signal stalker mode. In this mode, the radio automatically tunes to the closest signal. If you are in this mode, you will see what looks like a "C" with a circle around it, with what looks like the outer edges of a + sign behind it. Press "function" and "hold" repeatedly until this icon disappears from the screen.
For more information, you can download the complete operators manual from Uniden. The link is:
http://www.uniden.com/pdf/BC92XLTom.pdf
Hope this helps! Good luck!
SOURCE: CB92XLT hand held scanner keeps hissing and won't scan
Got the same issue man, you fix it? im checking mine over now, will let you know if i fix it. if you still need it.
SOURCE: BC72XLT scanner does not
what it is because that your other banks are locked out and thats why it by passes your frequencies...unlock your banks and it will stop on the transmissions...
