Bulova Watch Logo
A
Anonymous Posted on Mar 31, 2014
Reset alarm - Bulova Watch
How to set alarm in fastrack trendies 38047PP01 watch?
Unsure, as no manual shown after searching with https://www.google.com
The following site has this model watch for sale:
https://www.flipkart.com/fastrack-38045pp01-trendies-digital-watch-men/product-questions/itmf3zhnccdrbtxa?pid=WATF2Z4Z9SUKSZDZ
It does have a question and answer section on the web site, so perhaps you could ask the seller your question to be sure. Someone asked how to turn on and off the alarm below:
Questions and Answers
Q:How to turn off alarm..?
A:Press and Hold Reset & ST/STP buttons simultaneously for couple of seconds so that you'll hear a beep sound , that indicates your alarm is turned Off.(you can notice alarm ON symbol will dissappear
Q:What does wifi like symbol locate in watch .What it works?A:It says if alarm is on.
Q:how set alarm
A:Press mode button and press St button , reset button for setting Alarm has been activated
Mar 15, 2020 • Watches
I bought a watch for my grandson. It had no instructions. It is from China MFG# FMDAW549. Are there directions available
Possibly these instructions:
http://forums.watchnet.com/index.php?t=tree&goto=110449&rid=0
DIGITAL WATCH USER INSTRUCTIONS May 27, 2006 - 05:59 PM On 5/26/2006 I bought from Walmart a $6.43 watch, on the back of which is written "AH 1175, 52, Battery CR2025, China Module, FMD, Base Metal Bezel, Stainless Steel Back, 100ft Water Resistant". It has no control buttons on top (where buttons may be accidentally pushed), the display is larger and more visible, and the color is dark, so I bought it even though I prefer models that have a fabric/velcro wrist-strap.
Four buttons on this watch are labelled: Light, Mode, Reset, and St/Sp. The instructions which I found inside its container refer to the Light button as A, the Mode button as B, the Reset button as C, and the Start/Stop button as D, but otherwise do not pertain to the watch, so I determined the button's functions by trial and error, as follows:
TO SELECT THE DISPLAY MODE
Push the Mode Button in order to select one of the following four display modes in the following order: Normal Time, Stop Watch, Alarm Reset, Time Reset.
In the Normal Time Mode, the Day of Week, the Hour, Minute and Second are displayed (none flash). If the Alarm and Hourly Chime icons are not displayed, the Alarm and Hourly Chime are turned off.
TO DISPLAY DAY OF WEEK, HOUR, MINUTE, SECOND AND WHETHER THE ALARM AND HOURLY CHIMES ARE ON:
Push the Mode button until no icon is flashing. The Alarm and Hourly Chimes are off if no Alarm or Chime icon is displayed beside the Second display.
TO DISPLAY THE DAY, MONTH AND DAY OF WEEK AND WHETHER THE ALARM AND HOURLY CHIMES ARE ON:
In Normal Time Mode, push the Start/Stop button. The Alarm and Hourly Chimes are off if no Alarm or Chime icon is displayed.
TO DISPLAY THE ALARM TIME
In Normal Time Mode, push the Reset button. The P or A beside the Alarm Time indicates PM or AM time. The P or A below the Alarm Time indicates a 12 hour clock; an H indicates a 24 hour clock.
TO STOP/START THE ALARM AND HOURLY CHIMES
In Normal Time Mode, hold the Start/Stop button down and push the Reset button (the Date and Day of Week will be displayed) to turn the preset Alarm and Hourly Chimes on, or off (to save the battery). To test the alarm, hold the Reset button down. The alarm and chimes are off when the alarm and chimes icons are not displayed.
TO STOP THE HOURLY CHIME
In Normal Time Mode, hold down the Reset button (the Alarm Time will be displayed) and push the Mode button until the Day of Week display is no longer highlighted; otherwise the hourly chime drains the battery.
TO SET THE TIME
To Fast/Forward until the correct number is displayed, hold the Start/Stop button down.
To set the Month of the Year, select the Time Reset Mode and push the Reset button until the Month of the Year number flashes; push the Start/Stop button until the correct Month of the Year is displayed and push the Reset Button.
To set the Day of Month, select the Time Reset Mode and push the Reset button until the Day of Month number flashes; push the Start/Stop button until the correct Day of Month is displayed and push the Reset Button.
To set the Day of Week, select the Time Reset Mode and push the Reset button until the Day of Week display flashes; push the Start/Stop button to until the correct Day of Week is displayed and push the Reset Button.
To set the Hour, select the Time Reset Mode and push the Reset button until the Hour number flashes; push the Start/Stop button until the correct Hour is displayed and push the Reset Button. For a 24 hour clock, push the reset button until an H is displayed. For a 12 hour clock, push the reset button until an A or P is displayed.
To set the Second, select the Time Reset Mode and push the Reset button until the Second number flashes. The Second number resets to Zero everytime the Start/Stop button is pushed. If the Start/Stop button is pushed as soon as the Second hand on your computer and watch are the same, the watch will be accurate to one second (to set your computer time to the second, log on to the Internet, right click on your PC's time display, select ADJUST DATE/TIME, INTERNET TIME, UPDATE NOW). The setting of the Second number will not be affected by setting the Minute number afterwards.
After the Second number is set, set the Minute number by selecting the Time Reset Mode and pushing the Reset button until the Minute number flashes; push the Start/Stop button until the correct Minute is displayed and push the Reset Button.
TO SET THE ALARM TIME AND TURN ON THE ALARM
Choose the Alarm Reset Mode. The alarm is turned on everytime the Alarm time is reset.
To select the Hour, push the Start/Stop button while the Hour is flashing and until the correct Hour is displayed, then push the Reset button (the Alarm and Hourly Chime icons will appear).
To select the Minute, push the Start/Stop button while the Minute is flashing and until the correct Minute is displayed, then push the Reset button.
Push the Mode button after the correct Alarm Time has been selected. The Alarm and Hourly Chime icons will be displayed beside the Second numbers.
The P icon indicates PM. The A icon indicates AM. The H icon indicates a 24 hour clock.
TO USE THE STOP WATCH
Choose the Stop Watch Mode. Push the Start/Stop button to begin the lap time. To pause the Stop Watch push the Start/Stop button to stop it and push it again to continue. To reset the Stop Watch to zero, stop the lap time by pushing the Start/Stop button, then push the Reset button (otherwise the Stop Watch will continue counting after other Modes are selected).
Apr 20, 2018 • Watches
How do I set digital watch of UL1159
press MODE button 3 times on left screen DAY will flash press RESET MINUTE will flash, change minute what you want by pressing START.
press again RESET button HOUR will flash press START to change hour.
Press again RESET button DATE will flash change same way.
press again RESET button MONTH will flash change same way.
press again RESET button DAY will flash change same way.
After done press MODE to bring back normal time position.
Changing ALARM ....
press 2 times MODE button. Alarm HOUR will flash press START to set alarm hour.
Press again RESET button Alarm MINUTE will flash press START to change.
After done press MODE to bring back normal position.
SO YOUR TIME & ALARM GET SET. images?q=tbn:and9gctqfaospxemzn5ytb2yvmxsagwhcrw-zhdezmqvoulno244gvhvkgaae8w
2helpful
My husband would like the alarm off. i don't know how i did it but i set the alarm. please help me remove the alarm setting. thank you.
* Press the MODE button until you are in ALARM mode
* Press STOP/RESET (-) or START/SPLIT (+) to cycle through alarms
* When you have selected the alarm you wish to erase, hold down STOP/RESET (-) to clear the selected alarm
55helpful
2answers
Aw60447w digital watch. I cannot turn off the hourly beep. help
Hourly chime on/Off:
1.) Press and hold the lap/reset button (bottom right) to display alarm time
2.) While holding lap/reset button, press the mode button (bottom left)
3.) If the all the day of week indicators our lit, beep is on. If they are all off, beep is off.
Alarm On/Off:
A press of the lap/reset button (labeled) will show the alarm time, Unpress will show the time of day. Press again toshow the alarm time. Press and hold the lap/reset button will show the alarm time again, but it will hold there. While holding this lap/reset button, press the start/stop button (labeled). This will turn on (or off) the alarm (tiny indicator). Press this start/stop button repeatedly (while still holding the lap/reset button and you will see the indicator turning on and off with each press. Stop this button pressing with the indicator OFF, let up on the lap/reset button, and the time will return to the screen. The alarm will now be OFF.
Jan 26, 2010 • Swi Watches
57helpful
2answers
Can't turn off alarm
Here are the instructions to view, change alarm time and turn off alarm:
From normal time display:
Press MODE once to display stop watch.
Press MODE again to change alarm time.
Press MODE again to change time.
Press RESET once to display current alarm time.
Press and hold RESET then press START to turn on and off alarm (watch for alarm symbol on top left)
Press and hold RESET then press MODE to turn on daily alarm vs one time (watch day marker lines at the bottom)
Hope this helps.
May 05, 2009 • Watches
100helpful
4answers
Can't figure out how to deactivate the alarm on Umbro U564B watch
Start with watch in normal clock mode. press and hold bottom right "lap reset" - alarm time appears. Keeping "lap reset" held, I can then toggle the alarm on and off using top right "start/stop".
Qiu: Circle segment lights up (only a black point in the middle, NO ALARM)
Circle segment with a black section on the above middle point, ALARM ON.
5helpful
I have an Athletic Works watch and can not turn off the alarm.
the mode button controls the different functions of the watch.  time, alarm time, stopwatch, timeset, alarmset, in a repeating cycle.  Make sure you are on the time function (seconds ticking and changing every second, but not flashing twice per second.  This is the normal mode that shows the time.
183helpful
2answers
GapKids Watch turning off the alarm
If you don't have the instructions, the buttons are labeled as follows:
Top Left is "Light" - Button A
Bottom Left is "Mode" - Button B
Top Right is "Start" - Button C
Bottom Right is "Reset" - Button D
With the time displayed, press the reset ("D button as listed in the instructions) and the alarm time should be displayed. While holding the "D"/reset button down, press the start or "C" button to toggle the alarm on or off.
Hope this helps
14helpful
3answers
Setting a generic one-button digital watch
I too lost the instructions for my generic 4 button digital watch and had to find the functions by trial and error and the results are below.
Adjust Alarm/Time/Date - Press and hold Mode Button. When alarm displays, release. Start-Stop Button SELECTS, Lap-Reset Button ADJUSTS selection. Pressing the Mode Button again changes from Alarm to Time/Date, ADJUST as above. Pressing it again exits.
Select/Deselect Alarm, Hourly Chime or Both - Press and hold Lap-Reset Button, Start-Stop Button TOGGLES through the above options.
Select 12/24 Hour Mode - Press and hold Lap-Reset Button, Mode Button TOGGLES through the above options.
Select Stopwatch - Momentarily press the Mode Button, use the Start-Stop and Lap-Reset buttons to control.
Display Date - Press Start-Stop Button in normal time
display mode.
Display Alarm - Press and hold Lap-Reset Button in
normal time display mode.
Cancel Alarm - Press Lap-Reset Button in normal time
display mode to silence alarm.
Hope this is helpful,
George.
Nov 06, 2007 • Watches
Top Bulova Watches Experts
ZJ Limited
ZJ Limited
NOEL
NOEL
Are you a Bulova Watch Expert? Answer questions, earn points and help others
