Frigidaire 24 in. FDB1050REC Stainless Steel Built-in Dishwasher Logo
E
Edward barth Posted on Apr 03, 2017
Frigidair 1000 series dishwasher clean light staying on and not able to operate until I turn circuit breaker off and on.
I first had this problem a few days ago. Even when I turned the circuit breaker off and on a few times it did not work. With help from this site I thought I had it licked when I opened the top panel and cleaned the latch assembly. This worked - for one cycle. But since then the clean light stays on at the end of the cycle and can only be operational again once I turn the circuit breaker off and on. Since I don't think I can keep doing this indefinitely. I am wondering if it could be the seals. Maybe they are failing to the point of letting in too much moisture to the connections. I am hoping for a solution specific to this model. thanks to anyone who can help.
5 Related Answers
Anonymous
  • Posted on Feb 09, 2008
SOURCE: "Clean light" keeps blinking; dishwasher won't start new cycle
Check to see how it's loaded. If something is obstructing either of the spray arms it will not start. I had this same problem and checked to see if there was something impeding the arms - I found there was. Reloaded the unit and it's running like a champ now!
A
Anonymous
  • Posted on Mar 14, 2008
SOURCE: dishwasher will not turn on/ start cycle
Slam the door shut. What i did. I am guessing the switches in the door arent making good enough contact. When i slammed the door, it fired right up and ran fine
Anonymous
  • 71 Answers
  • Posted on Dec 21, 2008
SOURCE: frigidaire dishwasher not working
check electrical conectors to dw
Anonymous
  • Posted on Apr 11, 2009
SOURCE: Ignitors keep firing by themselves after my aunt cleaned them 24 hours ago
my dishwasher's handle broke off
Anonymous
  • 52 Answers
  • Posted on Jul 25, 2009
SOURCE: Dishwasher won't wash
pump is likely gone ......without pressure from the pump .the arms will not turn and no water will shoot from the arm jets .....it's kinda like a whirlpool tub that way .....no pump no bubbles ..good luck
Electrolux Dishwasher model EIDW6105GS1A, heavy light on, won't start. Turned off circuit breaker for dichwasher and the light turned back on and it won't start still. No lights on behind kickboard to show...
Good Morning Kim,
I see that the heavy light is staying lit on your Electrolux dishwasher, model# EIDW6105GS1QA, even after resetting your appliance at the circuit breaker. I also see that there are no lights lit up behind the kickboard, indicating what might be failing. It could possibly be the control board underneath your dishwasher. I suggest contacting your local authorized technician for further assistance. They will be able to diagnose your appliance and determine what is causing the heavy light to stay lit. I hope this is helpful.
-Best Regards-
WP
2answers
I have a frigidair Gallery Series Range. All of a sudden I get a F13 error code when I try to Bake or Broil
hmmm...can you go to the main circuit breaker panel, turn off the power to that unit, and reset it, by turning the breaker back on. You'll need to reset the clock after this, yet you may find you'll be in good stead.
Good Morning Edward,
I see that you are having trouble with running your Frigidaire dishwasher, model# FDB1050REC, due to the "Clean" light being stuck on. I also see that regardless of you trying to reset the appliance, it might run through one cycle and then you're back to showing the "clean" light, and not being able to clear that light. It sounds to me like your control panel is having issues and might need to be replaced. I do suggest contacting a local authorized technician to diagnose the appliance, this way you're not just purchasing random parts.
-Best Regards-
WP
1helpful
2answers
Frigidaire fghd2433kf dishwasher. less than a year old. flashed PF. the power hasnt been off. now whole unit is dead. no lights or movement.
Hello bidness_67 please check inside of the sink cabinet look for a switch on the back wall. If there is one flip it. Many new building electrical codes require a switchto turn off power to the dishwasher. Sometimes when putting items in the cabinet the switch is hit unknowingly. If there is no switch check outlets (the GFCI ones)and press the reset then check the dishwasher.if not those two items check breaker box for a tripped breaker.
The clean light stays on after running through the normal wash cycle quiet series 300 dishwasher serial no. mdb5601awq3
Some of the clean light's will not go off untill the door is opened, if your light still stays on, It could be a bad door latch switch or a Control board problem.
Jan 10, 2010 • Dishwashers
Cannot clear PF light flashing on frigidaire dishwasher
Frigidaire dishwasher will not work at all it has PF blinking
3helpful
2answers
Dishwasher will not start
Go to your electrical panel and turn off the circuit that feeds your dishwasher. It will also turn off the clean light. Wait three minutes and then turn the circuit back on. That should reset your machine.
Dishwasher Clean light blinks constantly.
Try turning off the power to the dishwasher at the circuit breaker box. leave the power off for 5 10 mins and then turn breaker back on and try to restart dishwasher. This may reset the board and it may work
Top Frigidaire Dishwashers Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a Frigidaire Dishwasher Expert? Answer questions, earn points and help others
