Good day Mrs. Thomas
If you have never changed your PIN before and you are trying to find it, your default PIN which is issued to you when you join Sky, is the last four digits of your Sky viewing card number.
Telephone your cell phone service provider and ask for your PUK code. (They are the only ones who can give it to you as it's the SIM card that locks rather than the phone.)
Enter a wrong PIN number 3 times and your SIM card will lock (if it's not already locked)
Turn off your phone and then turn it on again.
When you turn it on enter the PUK code. It will ask you for a new PIN. Enter a new PIN number and that will be the PIN you use from then on.
Keep the PUK code safe somewhere as you could need it again if you forget the PIN again.
You have accidentally activated the system lock or parental lock. This usually happens when 2 buttons are pressed on the remote simultaneously.
You will need to enter a PIN number using the numerical keys on your remote. If you have set a PIN number for this TV you will need to enter this. If not, you will need to enter the manufacturer's default PIN number. This is usually a simple combination such as 000, 111, 222, 123, etc,
I can't tell you the exact PIN number without knowing the model number of the TV. Please try the simple number combinations shown above and post back with the model number if you need further assistance. The model number can usually be found on a sticker on the rear of the TV.
There is no way I can pluck this out of thin air. You need to contact your bank and get them to reset your ATM pin number, then you need to change it straight away so you are the only one that knows your PIN number. Record your PIN number and keep it in a safe place, if someone knows your PIN they can empty your bank account.
pin number is never put on the unit. if u need a pin number its in the users manual/set up manual if u never changed the origanl pin upon setup. on the back of the router there should be a reset button pn sized of course which will set it back to manufacturers settings which will then take the origanl manufacturers pin number which is in the setup manual
the pin number is a number you create yourself for instance if you type in 0000 then the other person will need to type in 0000 too, to connect to your phone. Once you have connected once you will always be connected to that phone and will not need to put the pin number in again.
