Most dishes in any dishwasher are still wet when cycle is finished. The heat built up in the dishes during the washing cycle is what causes the water to evaporate when the machine stops.
If you want to accelerate the evaporation, simply open the door very slightly so that as the hot air escapes it causes the dishes to dry quicker.
HI HAVE YOUR PUMP FILTER CHECKED IF OK CHECK HEATING ELEMENT ..SEE IF ITS IN CIRCUIT.. THATS WHAT NORM HAPPENS IF THESE ARE NOT HAPPY.BET OF LUCK. MARK 07779933829
The water may not be getting hot enough in the rinse cycle. Usually it needs to heat to 140 to 160 degrees for rinsing. If the heating element is not working the water will not heat. If your DW has a Sanitary setting it will be calling for the water to be 160 degrees. If you have the option to override the Sanitary settin, try that to see if the rinse cycle will finish with cooler water.
Hi ii_goldie,What about the RINSE cycle... maybe the washer knows the "full cycle" is NOT finished.
The washer will display DONE... and make the door available to you. If not the cycle may not be finished. OR, turn it off, however, DON'T open the door if your machine has not drained all the water out, allow the system to finish.
michele99, So when you put it on drain, do you here the machine trying to drain the water? After it finishes draining, (you have to wait a few minutes, it should then have a blinking light
on the Finished/Door locked light.
Are you waiting for it to finish?
