I have a gx160 Honda Pressure washer Just started it for the first time this year.. Runs Great for about 20 seconds and shuts of oil levels look fine. ?????
Check for stuck float, plugged fuel filter or fuel line. All tanks have a screen inside them to catch larger particles, and some also have a inline fuel filter. If everything checks ok, the passages inside the carb are plugged, follow the cleaning procedure outline in the manual to be sure you only have to do the job once! Take a look at following link to see more solution to different small engine problems. http://solosmallengine.blogspot.com/
It could be several things...oil level, make sure its sitting on level ground...if not did you use StaBil when you laid her up for the season? If not, go to Advance Auto and buy "SeaFoam" and following directions run it for as long as it will run...make sure you have water running through the pump during tests!
Good Luck
