Have a Kenmore HE2t i keep getting error f21 i cleaned the trap and it still get the error f21
SOURCE: kenmore he2t error code 21
F21 is a long drain...it is taking too long to drain..you have a something slowing down the drain.. you can remove the bottom panel and clean out coin trap... if there is nothing then you may have another problem... but this is the most common problem..
SOURCE: I have a Kenmore HE2T error code F24
The "F24" error code is a heat sensor error code. The following link explains the error code in detail and the steps to correct it:
http://www.fixya.com/support/r1976126-f24_error_code_whirlpool_duet_kenmore
In many cases, the connector plug on the NTC sensor wiggles loose and causes the error code. Check the NTC connection first to make sure it is tight and making good contact. This may save you a service call and/or replacement parts. Make sure you UNPLUG the washer before servicing anything inside the unit.
A replacement NTC module (if required) can be purchased at searspartsdirect.com for about $10. Refer to the parts illustrations under the "Tub and Basket Parts" heading.
If you have any questions, please let me know. I hope this helps you.
NOTE: Each washer comes with a technical data sheet located inside the cabinet. You will need to remove the lower toe panel directly below the door to access it. If it is not located directly behind the panel, it will be affixed to one of the interior cabinet walls. The tech sheet includes all troubleshooting tips, wiring diagrams and fault codes with explanations.
Hello & Welcome to FixYa
F21 error is displayed when the washer is unable
to drain, press PAUSE/CANCEL button twice to clear the display. After this
please check the drain hose and drain pump filter for any blockages and make
sure it is not clogged with foreign particles. You can also check the drain
pump to verify that its working. Please get back to me if you have any other
questions.
Kevin
