Question about Lacoste L 2118 Glasses, Shiny Grey
What to order glasses nose pads?
Contact me back if there is available. lihan555@hotmail.com
    New Friend:
    Problem Solver:
  • 8 Answers
GO TO THE PLACE YOU BOUGHT THEM, I WENT TO COSTCO AND THEY HAD MINE GAVE THEEM TO ME FREE
Posted on May 03, 2019
6ya staff
SOURCE:
How to fix metal embedded plastic side bars of eye glasses?
the optometrist where you bought the glasses can adjust the nose bridge and side arms around your ears for free
that is normally done as part of the fitting/ sales process
Jan 17, 2018 | Televison & Video
Tip
Tip on how to clean sunglasses
Normal glass or plastic lenses, a quick dunk in warm water usually is enough. Or you can add a couple of drops of dishwashing detergent to get the tough grease. If warm water isn't readily available, a quick spray with a commercial window cleaner also can be used. But be careful if you have an anti-reflection coating on your lenses which is common on glasses that have been prescribed for night driving. These coated surfaces have been specially treated and certain liquids or detergents will often make matters worse by creating smudges on the lens. In these cases you should use an optical spray. The optical spray doesn't have to be specifically designed for sunglasses as any optical spray will work just fine including those designed for cameras..<br /><br />The surface of the nose pads are generally quite resistant to dirt and natural facial oils as they are usually made from a resistant type of plastic or acetate. However dirt can easily get wedged between the nose pads and their frame mounts. If this should happen just soak them for a couple of hours in warm water to loosen the residue. Then it's a simple task to gently brush away the unwanted dirt with an old soft bristle brush or old toothbrush.<br />Plastic frames, on the other hand, can form a greenish hue over time due to acidic reactions with the skin's natural oils. It is best to avoid the frame touching the face at all. If you properly adjust the nose pads inward to raise the glasses away from your face you can avoid this calamity. Once the frame has been damaged from the facial oils, it is almost impossible to remove the green coloration. Be sure to routinely tighten the screws of the frame.<br />By routinely inspecting your glasses and doing preventive maintenance, including regular rinsings in warm water with gentle drying, you can prevent dirt build up in the first place. Then you can enjoy your sunglasses more many years of service.
on Nov 07, 2010 | Clothing Accessories
I need a nose bridge or nose pads for my nike brazen glasses
The support team at Nike will ask that you send the frame back with a proof of purchase and 10$ to replace the whole front of the sunglasses.
18003526453 option 2
Jul 02, 2011 | Sport & Outdoor - Others
Although the clamp holding the glass is tightened as tightly as it can be, the glass slips down. Any solution?
If you add a few little rubber pads (like those eyeglass nose pieces) between the metal and glass, it will solve your problem.
Jun 05, 2011 | American Standard 5 ft Sliding Shower Door
Where can I order a two spare shoulder pad for the straps to my maxi cosi black car seat?
Good Afternoon
If you are a UK customer, replacement harness pads for the Maxi Cosi CabrioFix can be ordered via your local authorised retailer or direct with the customer service department on 01284 413 141 Mon-Fri 8.30-4.30. The harness pads are available in plain Black only, as a set of three, and are RRP £15 (with £3.99 p+p if ordered direct).
If you're in another country, go to www.maxi-cosi.com and select the country you're in, then use the "Contact Us" tab to ask if they're available in your country to order.
May 31, 2011 | Maxi-Cosi CabrioFix (Black Reflection)...
Rubber nose piece has split - barely hanging on
Hi.
The part (or the glasses) must be replaced. Cheap repair done with superglue is not a good solution. Please contact Nike customer support using the link below:
Athletic Sport Sunglasses & Technology ' Nike
Mar 27, 2011 | Nike Counter Sunglasses
Hello, I have Just Cavalli JC225 glasses. They were too tight and the arms were widened, to stop the glasses being pushed forward. Now they rest too heavily on my nose, causing red marks and...
There are a couple of things that can be done to fix this problem. One of the easiest solutions is to have the nose pads replaced with larger and/or softer nose pads. Alternatively, a saddle shaped nose pad can be helpful in distributing the weight across your nose. Most local optometrists should have nose pads available that they can change out for you.
Furthermore, if the nose pads are set at a bad angle they can dig into your nose also. Adding some curl to the end of the arms can bring the glasses closer to the face if they are sitting too low. If you are careful you can attempt some of these adjustments yourself.
Feb 25, 2011 | Roberto Cavalli Just Cavalli JC225 097...
Microwave is scratched
You will need the following:
Polishing compound, jeweler's rouge or whitening toothpaste
Electric buffer
Lamb's wool buffing pad
2 ounces of ammonia
2 quarts of water
Rubber gloves
Safety goggles
Lint-free paper towels or cloth
Step 1:
Apply polishing or jeweler's rouge to a lambs wool buffing pad. You can either buff the scratch by hand using a circular motion or with an electric buffer on medium speed.
Step 2:
Wash the polishing compound, jeweler's rouge or whitening toothpaste off from time to time in order to check on the progress of the scratch removal.
Step 3:
Mix two ounces of ammonia with two quarts of water. You may want to be sure to hold your nose closed during this process! Also, always wear rubber gloves and safety goggles when working with ammonia.
Step 4:
Clean the glass surface with the ammonia water with a clean soft sponge.
Step 5:
Dry the glass with a lint free towel. If the scratches are not completely gone, they should at least be less apparent. If there is no significant difference, consider contacting a glass company to replace or rebuff the glass.
Jul 27, 2009 | Frigidaire FMV156DC Microwave Oven
32 in hdtv with a 9in scratch across it how can i fix it cheep
If the front of the screen is glass, then follow these steps:
  • Step 1 Apply polishing or jeweler's rouge to a lambs wool buffing pad. You can either buff the scratch by hand using a circular motion or with an electric buffer on medium speed.
  • Step 2 Wash the polishing compound, jeweler's rouge or whitening toothpaste off from time to time in order to check on the progress of the scratch removal.
  • Step 3 Mix two ounces of ammonia with two quarts of water. You may want to be sure to hold your nose closed during this process! Also, always wear rubber gloves and safety goggles when working with ammonia.
  • Step 4 Clean the glass surface with the ammonia water with a clean soft sponge.
  • Step 5 Dry the glass with a lint free towel. If the scratches are not completely gone, they should at least be less apparent. If there is no significant difference, consider contacting a glass company to rebuff the glass.
May 09, 2009 | Sylvania 6842PE 42 in. HD-Ready Plasma...
Lacoste L 2118 Glasses, Shiny Grey Logo
801 people viewed this question
Top Lacoste Work Safety Experts
STEVE
Johan Erasmus
Johan Erasmus
James Boyd
Level 1 Expert
Are you a Lacoste Work Safety Expert? Answer questions, earn points and help others
