Frigidaire ATF6000ES Front Load Washer Logo
A
Anonymous Posted on Mar 17, 2014
Does frigidare washer model fafw3801w3 have pump filter
1helpful
2answers
Where is the filter on my Electrolux front loader washer?
You may need to remove the front panel like on my Frigidare washer. Removing the retaining spring ring holding the seal may be tricky.
I learned from watching a repairman do it.
My filter got clogged because the drum impellers tend to break a piece and let change and stuff go to the filter.
My frigidare crown series washer won't drain the
Remove the back cover and later the drum drain pipe. If a filter is present, dismantle and clean out. Most often the cause is a object that that is hindering the operation of the spinning pump. Dismantle and clean the pump.
Frigidare washer, model LST6000ESO will not spin water out of the clothes.
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
3helpful
Need to locate lint trap on washer....affinity frigidare front load washer
There is no lint trap on this washer. There is a filter in the hose that goes from the tub to the pump that occasionally will get plugged with lint, but it is not designed to be regularly cleaned. During normal usage, the lint is designed to be pumped out with the water.
Kelly
3helpful
Error code 20 Frigidare front washer won't spin water all over floor
error code 20 is a drainage issue,check the drainage pipe at the back of the machine if its kinked or blocked,also check the pump filter behind the front panel underneath the drum at the front of the machine if its clogged,unclogge. if after you unblock the drain pipe and clean the pump the problem still persists then the pump is bad,if you cant do it your self you can get a tech to clean it for you.hope this helps
I have a Frigidare washer/dryer combo (model # FLEB8200DS0). My wife washed a heavy load and the washer stopped draining completely. Agitator works fine. Please HELP...
I'm not sure if the heavy load had anything to do with it or not. this unit has a remote pump, which means the pump doesn't run off of the main belt . It actually has a motor of it's own. Basically you would have to remove the front access panel, of course unplug from power, make sure the pump will turn. with the power off you can rotate the cooling fins on the pump motor. if it turns freely then you would have to determine if the pump motor is getting power. If it is getting power then you need to replace the motor.
1helpful
WONT DRAIN
clean the pump and also make sure that the pump motor is powered during draining
Water leaking from bottom of frigidare washer
You really don't have to take a panel off, depending on your washer model. All you would have to do, is flip the washer over on its side and check underneath.
Frigidare front load washer
check to make sure you have removed all the shipping braces
1helpful
Frigidare front load washing macine leaks water
Sounds like the dispenser is leaking somehow, there is no filter that would cause it to leak. Remove lid of washer by screws on back lip and inspect during fill to see where leak is.
Top Frigidaire Washing Machines Experts
ZJ Limited
ZJ Limited
Mike Cairns
Mike Cairns
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
