LTD Watch Bowflex Strapless Heart Rate Monitor watch Logo
A
Anonymous Posted on Mar 16, 2014
Replacing battery on bowflex pulse heart rate monitor
Heart rate display is not showing correctly - it's too high
It is easy to check your heart rate. Place your index finger on your carotid artery on your neck. count the pulse for the seconds. multiply by 6 for beats per minute. If it does not match your monitor contact customer service for repair. If it does match your monitor call your cardiologist.
http://www.raytech.ca/en/services/repair_service.asp
Polar AXN300 Heart Rate Monitor Watch HRM AXN300 is not showing pulse
I would think it is the sensor circuit in the watch. When you replaced the battery did you activate the processor all reset for the watch? I do not know on your model where or how this would be activated.
Electronic watches normally have a reset procedure for when the battery is changed. Very important the watch's processor reset is performed after changing the battery. This is not any of the user readings reset. This is a reset for the watch's processor and system. It is sometimes a contact that has to be shorted out with the jeweler's screwdriver, or it is a contact that has to be shunted, or etc., depending on the model. Maybe if you call the support for the watch they will tell you this. Normally they do not like the user opening the watch.
4helpful
I own a bowflex precisionxt heart rate monitor and I cannot find the manual. Where can I obtain one?
Try this:
search-manual-online.com/bowflex-precision-xt-heart-rate...
Aug 29, 2011 • Watches
I just put a new battery in the Polar F4 heart rate monitor watch and it does not work. The battery died about 2 years ago and I never replaced it until now. How can I get the heart rate monitor working...
This is a common issue. The Polars and other Heart Rate monitors are not designed to be fixed by the consumers except for very specific models. These only look like watches, they are in fact mini computers and very susceptible to internal damage if not handled properly.
You need to send the unit it to a Polar Authorized Service Center to have fixed properly. There is not reset within the computer, if you had done everything correctly then it would work.
I can't get my Polar F4 to read my heart rate. I wet the transmitter and it still won't read my heart rate.
are you sure your not dead ,, ask someone to check your pulse , try it one someone else ,
I have a mio euorfit heart monitor watch. During my workout I
Yes, you definetely need battery replacement.
As the hart rate monitoring is most sophisticated part of the device, it has more IC (Integrated Circuits) than any other features.
More IC's means more power is needed, so, if the heart rate monitor is starting to malfunction, that's the very first sign of underpowered battery.
Find your nearest watch repair shop and ask for battery replacement.
Do not forget to rate, please.
1helpful
Polar f11
no it shouldnt be cause the heart rate would be based off your pulse
im not a heart specialist but ive had my share of heart polups and a faulty valve in my heart
i was told by my doctor that the heart rate is monitored by bloodpreasure threw the veins pulse so i dont think that the size of the watch would make a difference this is in my opinion based off my own docs words hes the doc what can i say
but recommend that you speak with your doctor about heart monitor watches they know more indepth about these devices or your local pharmacy
i hope this helped you out
Chenge the battery
Response to Wasilij: The belt is sealed, so it can be used while swimming. It's not meant to be opened. They replace the whole thing, instead of replacing the battery. So sorry, not going to work.
Top LTD Watch Watches Experts
john h
ADMIN Andrew
ADMIN Andrew
ADMIN Eric
ADMIN Eric
Are you a LTD Watch Watch Expert? Answer questions, earn points and help others
