Question about Roper RT18DKXKQ / RT18DKXKT Top Freezer Refrigerator
Not cooling fan is running i cylced the defrost time fan stays off then cylce it again and the fan comes on but it doesnt feel like compresseor is not coming on
Tv comes on stays on about 3 minutes then goes off power light flashes about 40 times then it comes back on this cylce is repeated over and over
have u replaced the lamp? also do you have any other symptoms .I had a customer call me with same symptoms this morning.i also told him to listen for any noisy motors or cooling fan problems.he said his played and blinked 67 times then would repeat cycle he also said unplugging it for a day then plugging it back in made it play fine for 3 days
Feb 18, 2011 | Sony KDF46E3000 46" Television
Refrigerator runs, cools (freezer too), then stops cooling for a few days (freezer stays somewhat cool), then starts cooling again. Help...:(
In these new fangled ice boxs is what you call adaptive defrost control. Instead of the old tried and true defrost timer, brainiacs have decided to use artificial intelligence to determine defrost.
The basic pattern of adaptive defrost is:
COOLING,PRE-CHILL,DEFROST,DWELL,and POST-DWELL.
Hey I ain't making this up. The ADC (adaptive defrost control) Counts the number of times the doors are opened, the total compressor run time, and the length of time the defrost heaters were on during the last defrost. This method supposedly enables the adc to work nice in all kinds of conditions, whether hot and humid or cold and frigid climates. COOLING Mode will remain for an indefinite time or until defrost is determined by the micro-processor. When all systems are go for defrost the adc makes the jump to light speed by going into PRE-CHILL, this brings down the temps in the freezer to off set the defrost operation so that the food temp does not suffer dramatic temp rises. Pretty cool ain't it? If the ice box is in pre chill and the door gets opened then a DEFROST HOLD OFF will jump in and not do a defrost for several hours. If the door is continually opened at the end of 16 hours the adc is gonna defrost that ice box anyway. The defrost period varies but is a maximum time of 45 minutes including when the DWELL kicks in. Dwell is the length of time the ice box stays off AFTER the heater is terminated.
Then The POST DWELL will kick in. The post dwell will fire up the compressor and condenser fan but the inside fans will not run allowing the coils inside to cool down before them fans kick in and she jumps back into Cooling mode. I bet you would like to have a copy of GE's adc repair manual wouldn't you?
TECHNICAL SERVICE GUIDE
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Dec 22, 2009 | Kenmore Refrigerators
I need help or repair for my LG Refrig
could be ice on or around the fan...when the fan hits ice it makes noize....
Nov 11, 2009 | Refrigerators
Battery died, replaced the battery. now car will start and when i let off the gas the car shuts off. 99 honda accord
be VERY easy when letting off the gas and make sure everything is off the car needs to "find" its self let it idle till you hear the cooling fans cylce on and off twice then let it sit for five minutes running. this can be time consuming
Oct 01, 2009 | 1998 Honda Accord
AMANA TZ21QW DEFROSTING DRAIN TUBE FREEZES UP AND FORCES WATER INTO THE REFRIGERATOR.
Once you completely defrost the unit, you can actually take part of a metal coat hanger and create a hook and straight peice that will partly stick into the drain. You hang it from the evaporator so when it goes through its defrost cylce it will melt any potential ice inside the drain tube. Also make sure the drain run clear with hot water before turning the refridgerator back on.
I’m happy to help further over the phone at https://www.6ya.com/expert/josh_87ce33216d7b2148
Aug 29, 2009 | Refrigerators
AC turn off before it reaches the desired temp
Hi there. I assume the indoor fan runs continuously until the house has cooled down. Clean the condenser. (outside unit)
Another possibility is that the system is getting low on freon. Check for leaks with soapy water at all joints and fix them.
Thanks
Paul
Jul 13, 2009 | Ruud UAKA060 Air Conditioner
Frigidaire FRS2345AB9 Not Getting Cold Enough
Check the fan in the freezer side to make sure it is running. If the fan is running and you have frost, then you have a defrost problem, Heater is not coming on to melt ice. If fan is not running replace fan.
Mar 09, 2009 | Frigidaire FRS23H5AS Side by Side...
Roper RT18DKXKQ / RT18DKXKT Top Freezer Refrigerator Logo
32 people viewed this question
Top Roper Refrigerators Experts
John Tripp
John Tripp
Bruce Denton
Gil Shultz
Are you a Roper Refrigerator Expert? Answer questions, earn points and help others
