John Deere 6300,6300l,6400,6400l Tractor Radiator Logo
A
Anonymous Posted on Mar 15, 2014
Adding freon to ac - John Deere 6300,6300l,6400,6400l Tractor Radiator
My AC stopped working. I can see that the compressor clutch is not engaging. My Freon pressure was very low so I added to the proper level. But still doesn't work.
I need year--make--model?
You removed the fuse and used paper clip in the fuse socket? I'm just trying to understand what you did with paper clip?
95 Path finder se ac button no working. No ac at all. Previous owner installed radio since last time he used ac. How can I fix this other than adding freon?
adding Freon may not be the answer but will cause unnecessary problems if not done by a specialist. Have an accredited ac specialist look at the problem as the ac may not be working because of a leak in the system. He may have also used the power wire for the radio and so there is less current available to work the ac.
Air conditioner electric circuit
Try disconnecting battery for two minutes to reset the system. Then start the car and check a/c operation.
Should i see bubles n the little glass when i've added enough freon to the A.C.
You will see bubbles when freon is low....so, keep adding freon untill you see "no more bubbles" (clear)..as soon as it is clear STOP adding freon...You should be good to GO...
2helpful
I have a Montero Sport 2003, last week I had Freon added to be prepared for the summer, I noticed a noise and ask the mechanic, he said it was the fan but nothing to worry about. I drove the Montero for 2...
If the noise started after you added the Freon, then it perhaps is your AC clutch. Normally if you have an automatic AC system, then when the Freon gets low, the auto system will not allow the AC to engage, only allowing the fan to circulate outside air. In order to add Freon to the system, the AC lock out has to be over ridden, in order for the compressor to **** in the Freon. This in turn engages the AC system so that the clutch engages, thus engages your AC system. The clutch bearings may be at fault.
2answers
Added freon to ac and car will not cool
Needs to be checked for a freon leak, best way to do this is to recharge and add dye, with a uv light you will be able to fine the leak, most auto parts sell the dye, and the flash light you will need to fine the leak, good luck.
2answers
2001 Isuzu Rodeo LS after adding Freon A.C runs warm and cold
It sounds like by adding refrigerant to the system it may be over pressurizing. When this happens it will cycle on and off.
You will need to hook up a set of manifold gauges and monitor the high and low pressures to see what is happening.
1helpful
Adding freon to the auto air conditioner, the
On that model,it will cycle on and off while you add freon.If it does not ,then the ac system might have a problem.The low side pressure switch is located on,or near the accumulator .Unplug the switch and take the wire end plug and connect the two plug in`s together(cross it out on the wire).This will make the ac compressor engage and you can charge the system,do not leave the wire connected,plug it back up to switch.If the ac compressor does not come on ,then have the system checked out.
2answers
My ac does not blow cold in my 97 cadillac deville but it does blow just not cold and its n ot the fuse what can i do?
You probably have leaked out your freon after so much time. Try adding some more Freon if it doesnt stay charged you may have bigger issues.
5helpful
My ac blow out hot air and i want to put freon in my self and want to know how
Adding freon will not correct the problem. If you need to add freon, you have a leak, and you have moisture in the system, the leak should be located, mositure removed, then freon added. But to answer your question. Open the hood on, the left side you will see a round object called a dryer, you will see two pipes coming from it, one at the top and one at the bottom. The smaller is the high side, the larger is the low side. Obtain a can of freon either R-22 or 134a with an adapter for installing the freon. Turn the engine on, turn the AC to high. Add the freon to the ac using the low side.
Top John Deere Garden Experts
john h
Sean Wright
Sean Wright
Jay Finke
Jay Finke
Are you a John Deere Garden Expert? Answer questions, earn points and help others
