I was told that I could pry off the trim around the ice/water/crushed ice in door assembly then change out the control panel. I cannot get the trim around the assembly to come off. I don't know if there are screws from the back side and I have to tear the door apart or it will pop off with enough pressure.
SOURCE: Ice & water control buttons
sound like a bad(shorted) dispenser user interface INTERFACE DISP ASM WR55X10415
SOURCE: ice/water dispenser control panel
@ Scootertramp
You tell us about this board or that board but never tell us where to located or get at these boards. Would you please clarify that?
My ice and water started dispensing sporadically, though the lights were working fine. After I removed the kick board at the bottom, cleaned out the little connector and put it back together, nothing on the door works. All else works fine.
SOURCE: PSS26PSTA SS - Only dispenses crushed ice.
Remove the ice dispenser bucket. You will see a square hole at the back wall with a horizontal rod in it. You should be able to move it up and down with you fingers. If not, it may just be frozen. Warm it with a hair blower and try again. If still no luck, the WR62X58 dispenser solenoid may be burnt out / melted and need to be replaced. It is attached to the metal just above and behind that square hole. The removable tray at the bottom of the dispenser recess is a part number WR17X12133 for a PSS26PSTA SS. Contact any GE servicing dealer or general appliance servicer near you to get one. You can get parts direct from GE also, but the won't be any cheaper, and you may pay more shipping and handling.
SOURCE: GE side by side by side,water drips from bottom freezer door
I have the same problem. Just talked to a friend that's a great appliance repairman. he said I have to remove the panel in the back inside of freezer and there is a drain that gets clogged up, a little hole or tube.
clean that and should work fine and stop leaking. I haven't had time yet, but this weekend I'll do the deed. Hopes this helps ya!
SOURCE: ice dispenser will not switch back to cubed from crushed
Had the same problem, dispenser stuck on crushed ice, even when cubed ice is selected. There is a magnetic switch behind the panel where the motor for the ice dispenser is. It gets water in it and freezes so it is not free to go up and down. It is always down for crushed, but for cubed ice, the magnet pulls it up. when it's frozen with ice, all you'll get is crushed. You'll have to defrost it. You can defrost the whole freezer, but better to just remove the ice dispenser and defrost that. Three 1/4'' bolts hold secure it. You'll have to unplug the wires from the back of the freezer to remove the unit. The just let it defrost and dry. You can remove the switch from the panel and dry it out too. I've had to to this several times and am looking for a solution to keeping water out of the thing so it won't freeze again. Has anybody solved that?
My through the dor systems all work. I can get ice, crushed ice and water. The touch panel on the door is damaged due to fingers pressing on the pressure sensitive "buttons" and I want to replace this touch pad. I just can't figure out how to take it apart.
