Nokia C503 Cell Phone Logo
D
Durley Ribeiro Mussa Posted on Mar 14, 2014
When i turn on my cell phone it vibes but dosent apear the image
Susan Lee
Level 1:
New Friend:
  • Contributor 15 Answers
  • Posted on Mar 14, 2014
Susan Lee
Contributor
Level 1:
New Friend:
Answers
15
Questions
Helped
946
Points
26
Did you drop it, did water get in it?
Is it contract or prepaid?
Contract:- take it to your cell store and tell them they will look at it and possibly replace it. Prepaid take it to a cell repair shop and have them look at it. May be a screen problem which the store and repair shops can likely fix.
Hope this helps.
In nokia 1650 when i insert battery it automatically vibrat
Does it vibe all the time or only when you install the battery? There is phones that vibe when you install the battery. If ot only vibes and does nothing it can be SW issue or Water damage. Please visit www.awsrepairs.com/ for all your wireless needs.
NEED NP CODE FOR T-MOBILE VIBE
NP code and Network unlock code are same...You can get the unlock code from the site
Onlinegsmunlock.com/t-mobile-e200-vibe/rs7wp9/ and unlock Your T-Mobile E200 Vibe Phone from network lock (T-MOBILE LOCK) Then use O2 SIM CARD IN IT.
Oct 04, 2012 • Cell Phones
Free unlock code for vibe e200
you can try superunlockcodes to get unlock code for your vibe e200 and get it unlocked..dont go for free unlocking since the code generated for free may some times go wrong..
1helpful
My sciphone deam g2 w/wifi turn on but only apears the brand and model and then the screen is turn off but not the telephone. Not reponse any comand. If I conect the data cable apears the android image...
Try a hard reset, if not go directly with manufacturer and upload soft version, that always fix its, also try hard reset by Hardware Keys but unless you have flashed it, it dosent come it android. take care
Sep 22, 2011 • Cell Phones
6helpful
2answers
My samsung champ always appear connected to pc! and it always apear to be charging even if unplugged?what should i do?
My samsung champ always appear connected to pc! and it always apear to be charging even if unplugged?what should i do? thnx...
How to know whether my touch diamond is 3G enabled or not? It dosent have front camer
Hi! When it's on 3G, on the top of the screen, to the right, will be a 3G icon. Here is a picture of your phone when in 3G: http://www.letsgomobile.org/images/news/htc/htc-touch_diamond.jpg
Ringer volume is low
Motorolas generally have a very low ringtone.The only solution is to find the loudest one on the phone and turn it up to the max.or alternativly go to settings-ring sytles-and change to vibe/ring.This will vibrate the phone first.if you phone is in your pocket or bag you should feel it vibe first than ring.
In vibrate mode, phone continues to vibrate after being answered
The phone is in "vibe then ring" mode.
Go to tools then ring styles using the "-" at the top center of the keypad. It will be set to vibe then ring, press "change" alter the style to vibe, vibe then ring, silent, loud or whatever you like. That is also where you find what ringtone is used for the ring.
Phone Not ringing
do you happen to work with steel alot? I work for a steel company building fans, and I got a ton! of steel shavings stuck to the speaker in my phone, I took it apart and cleaned the dust off the speaker with a can of air, compressor should work too... all i did was remove the 2 larger screws in the lower part of the battery bay and carefully removed the back, voiding my warenty but BE CAREFUL all of the brains of the phone are in that compartment and you can turn it into a paper weight pretty quick but I survived and it only took a few min, i lived with having my phone on vibe for only a week and it was horrid. hope this helps!
Top Nokia Cell Phones Experts
Kolbrun...
Muhammad Irshad...
Muhammad Irshad...
