https://www.i
fixit.com/.../Why+is+the+%22F+dl%22+light+come+o...
iFixitThese are the errors for error code F/dL Door Lock Error Condition A Door Lock ... orrepair the following Door Lock Mechanism broken or removed from the Door ... these are usually indications of a failed door latch assembly and will require replacement. ...FdL code would not reset until I turned washer on to start load.
www.dexter.com/support/
troubleshooting/
Dexter Washer Troubleshooting. Select your problem form the following list to reveal a list of possible solutions and supporting documentation. Constant ... F1 / Door Lock Error Door failed to lock properly. + ... Error Code F13, F15, F17, F19 +.
www.appliancefactoryparts.com/blog/.../washing-machine-fault-
codes/
Feb 20, 2010 - Failure Code, Condition, Check/Repair. "F1?, Water ... "F7?, Door lockrelease fault, ?· Bent pull-rod for door latch. ?· Bad door latch ... Water overflow error, Water supply does not stop after sensing an overflow condition. Turn off household water supply to washer and unplug power cord. ?· Check wiring ...
The door closes but the machine wont start. All the controls lights are on.
Same thing - door closes, all seems well, no error codes but the cycle selection flashes and the washer won't start.
Same thing. Everyting looks normal but the door doesn't lock and the machine cycle doesn't start. How hard is it to replace the switch?
I get an error code of DL, meaning the door won't lock. It keeps clicking for about 10 seconds, as if trying to lock. Then sure enough, it beeps and displays the DL code. I'm so frustrated I'd like to put a brick through it.
