Amana ABB2224DEW / ABB2224DEQ / ABB2224DEB Bottom Freezer Refrigerator Logo
Posted on Mar 11, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Refrigerator freezing food. Bottom freezer works ok.
Amana refrigerator, bottom freezer. ABB2222FEW. Refrigerator is freezing food. Freezer is working OK. I took the cover off the damper and it seems to stay open all the time. I want to check the thermistor but need instructions on how to access it at the top of the refrigerator behind the thermostat digital settings
David L
Level 2:
Scholar:
  • Expert 135 Answers
  • Posted on Mar 11, 2014
 David L
Expert
Level 2:
Scholar:
Answers
135
Questions
0
Helped
22383
Points
350
Amana ABB2222FE
There is your user manual :)
Its the first one on that link.
5 Related Answers
Anonymous
  • 706 Answers
  • Posted on Aug 06, 2008
SOURCE: Amana ARB1917CSR ? Refrigerator freezing food, (bottom) freezer working OK
I picked up on something you wrote within your problem description. "got the thermostat replaced under warranty" & "that worked for a while ". back in Aug of 2002. It's August of 2008 and your thermostat may have failed again. 6 years later... not so unusual. Anyway, since your fridge has a bottom freezer, there must be a pass thru between the freezer and the fridge compartment in an area you haven't examined yet. The fridge gets cold air delivered from the freezer to keep it cold thru this pass thru and many fridges have an adjustable flap that allows you to limit that cold air flow. Time permitting, can you do a more thorough examination of the fridge area ( side walls near crisper drawers perhaps?) or better than that, remove the drawers and look for that air duct pass thru. Once located, if it does not have an adjustable damper, try a little duct tape to limit the amount of cold air from migrating into the fridge compartment. Other options: Can you contact Amana customer support directly and get their support? That particular model has been discontinued by Amana but they should be able to support it. Not sure I added anything to what you already know. Gave it a shot thou...
Anonymous
  • 1214 Answers
  • Posted on Jan 16, 2009
SOURCE: anama bottom freezer
Chances are if they are getting cool -
1) the evaporator fan in the freezer is not running
2) Defrost heater has failed
3) Defrost sensor has failed
4) Defrost timer/refrigerator control has failed.
Check for ice build-up on the back wall of the freezer. If there is ice, unplug or turn the unit off for 6-8 hours with the doors open (put any food in a cooler with ice to maintain). Note water may come out of the refrigerator/freezer.
Plug the unit back in or turn it back on, close the doors, and check temperature after a couple of hours of operation. If all OK, you will need to have the above tested, or, if you know how to use a multimeter and can read a schematic/wiring diagram, I can instruct you on how to check the above.
Anonymous
  • 1214 Answers
  • Posted on Jan 20, 2009
SOURCE: amana refrigerator warm
Chances are if they are getting cool but not cold-
Check for ice build-up on the back wall of the freezer. If there is ice, unplug or turn the unit off for 6-8 hours with the doors open (put any food in a cooler with ice to maintain). Note water may come out of the refrigerator.
Anonymous
  • 1122 Answers
  • Posted on Mar 16, 2009
SOURCE: Bottom freezer on Amana refrigerator is too warm,
is there frost building up in the back of the freezer wall?mike
Anonymous
  • 43501 Answers
  • Posted on May 25, 2010
SOURCE: Top refrigerator part not cooling, bottom freezer and fan working
There are a few reasons why the refrigerator part will not cool...here are a couple of tips that will help you to figure out why the refrigerantor is not cooling...
Refrigerator2_bing.gif not Cooling or Fridge not Cooling
http://www.fixya.com/support/r3662945-refrigerator_not_cooling_or_fridge_not
How to Defrost Refrigerator Defrost Timer Problem
http://www.fixya.com/support/r3771673-defrost_refrigerator_defrost_timer
heatman101
Amana fridge abb2222few not cooling but freezer is working where is fan motor located for fridge section
its in the freezer near the top if its not cooling I would check ur air damper flow control, is it to far close or opened? check the cold control thermostat, the thermistors. and of course the fan itself, check door seals.
1helpful
Frost is building up in bottom freezer. Appliance is running nonstop. I believe that the freezer drawer has been shut completely. Foods in refrigerator section are fine; foods in freezer section are...
Frost can build up for multiple reasons. Most common is the start os an iceblock. Other reasons can include condensation from door being left open or opening too much. It can also happen from backsplash from the inlet tube for the ice maker. If the fridge is running non stop. It sounds like the ice block is forming and the temps are not getting to the program temps. If at factory setting the freezer should be at or around 0 degrees and fridge should be between 42 and 48 degrees. Has the fridge shutdown at all to go into defrost? The defrost timer may have went out and is causing an iceblock. If there is an ice block always change bimetal/ defrost thermostat.
If you need any further assistacne please feel free to comment me.
1helpful
Our Amana bottom freezer refrigerator is too cold in the refrigerator portion. It keeps freezing all the fruits and vegetables even though the temperature is set on the warmest setting in both the...
Hi, There can be many reasons why your refrigerator is freezingyour food. To see what could be happening and to figure out how to possibly fixyour problem. Take a look at this tip which contains many of the causes andsolutions to fix the problems.
Refrigeratoris Too Cold and Freezing Food
heatman101
Ice crystals are forming throughout my bottom freezer
There can be many reasons why your refrigerator is freezing your food. To see what could be happening and to figure out how to possibly fix your problem. Take a look at this tip which contains many of the causes and solutions to fix the problems.
Refrigerator is Too Cold and Freezing Food
heatman101
My Amana ABB2222FEW refrigerator is not cooling, but the bottom freezer is working fine. What can I look for?
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Amana bottom freezer model ABB2227DES--food in fridge is freezing when it didn't before.
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
heatman101
Amana abb1922few bottom freezer refrigerator freezes in the ref section freezer ok
Good day,
The air going to the fresh food compartment is controlled by a pneumatic damper which varies the amount of air going to the food compartment. Many times it pops the spring off that tries to keep the flap open. It is located at the top rear. Look here.
If it proves to check out ok. (I'd take it to an appliance parts house to let them see it,) it would be the control that regulates it's opening position.
1helpful
Amana BX20RW Refrigerator slightly warm freezer not freezing
Check the thermostat, to make sure that it is working properly. The theremostat is a long wire in the top of the freezer up near the fan. If that is bad it will not let your freezer cool correctly
3helpful
Anama bottom freezer
1helpful
Amana bottom freezer - food is freezing in refrigerator
heatman101
Top Amana Refrigerators Experts
ZJ Limited
ZJ Limited
Jay Finke
Jay Finke
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
