You need to use Windows disc to fix the boot up problem. Later, before you download any update, please test and fix the operating system using this Norton Utility:
http://download.cnet.com/Norton-Utilities/3000-18512_4-10907620.html
SOURCE: how to enable internet on Dell Precision M4400
fistly confir that which antivirus u use.
if it norten, thn follow these step.
Scan for Internet-Enabled Programs and Apply Firewall Rules Using the Interface
Note:
All the programs that you select appear in the Program Control dialog box. In almost all cases, you do not need to modify the Internet Access or Category options. If you do need to modify these options, click the triangle to the left of the option in the Internet Access column and select the change.
If the application is still not working with your Internet connection, proceed to Check if a rule in Norton Internet Security or Norton Personal Firewall is Blocking Internet Access
SOURCE: Dell precision m4400 blue screening
"BSOD" also known as "Blue Screen of Death" occurs when system is not stable due to misconfiguration or driver incompatabilty or Virus or worm infection.
Method 1 : Start your system by pressing F8 upon startup. Select "last know good configuration that works".check this one solve your porblem.
Method 2 : Start your system by pressing F8 upon startup. Select "safe boot "and check if it work or able to log you into your Desktop.
Uninstalled any software or hardware you have recently added or installed.Click "Start", Select "Run", type "msconfig"
Again click "Startup" tab.Untick all the program thats loads during your system Boot up.
Method 3: Start your system by pressing F8 upon startup. Select "safe boot "and check if it works or able to log you into your Desktop.
Click "Start", and then select "All programs", then "Accessories".Select "system tools" and then "System Restore".Try to restore your PC to a point or date which you know it was working fine.
Method 4 : If none of the above workor you are able to boot it. Then download "Hiren's Boot CD"
Here is the link
http://hirens.longcomputerservices.com/Hirens.BootCD.10.1.zip
Download the file and burn the ISO image in a CD.Boot your system using that CD. It has lots of tools for repairing Windows, system restore, Data recovery etc.Check if it can fix your problem.
If Hiren's Boot CD can't fix it then Backup all your important datas and go for a new install.
Don't forget to create system restore point whenever you are going to make changes to your system.It will help you in recovering during the time of failure.
HAPPY NEW YEAR.
