Omega 8003 Nutrition Center Juicer Logo
T
T Smart Posted on Mar 11, 2014
JUICER WILL ONLY GO IN REVERSE - Omega 8003 Nutrition Center Juicer
JP2400
Level 1:
New Friend:
  • Contributor 2 Answers
  • Posted on Jun 05, 2015
JP2400
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
3001
Points
I talked to an Omega tech, and he walked me through a home fix. If you open the juicer and look at the switch from below there are two sets of connections. Just move the red, blue, white connections to the opposite side (make sure the unit is unplugged when doing this).
Omega 8003 will only reverse
How to open the morphy richards
The Instruction Book for your juicer can be found here:
http://www.morphyrichards.co.uk/Downloads/InstructionBooklets/IB48951.PDF
Please refer to page 5 for illustrated directions on how to assemble. Disassemble in reverse.
The plunger to my Jack Lalanne juicer is stuck making it impossible to continue juicing. Nothing is blocking the blade or other parts. Can you help? Carol
this happens to me a lot. Take the lid off the juicer and turn the lid upside down take a hammer preferably a rubber mallet one and gently tap the bottom of the plunger while holding it upside down with bottom part of plunger up to your vision field tape it on bottom while trying to turn it into the right position (flat side to flat side) from the top putting a little torque on it..when it is tapped with a hammer or some similar tool far enough up the tube in reverse, it will then turn into the right spot if you tap the bottom with one hand while turning t to the right position on the top of the plunger and will be able to be removed but do not tap hard enough to break it.
1helpful
2answers
Where do I buy a replacement gasket for breville fountain elite juicer?
However reliable and durable your Juicer is, at one point in time it will need Replacement of parts. It is Great to buy a model from an established brand like Breville, where Juicer parts or accessories for these juicer machines are easily available.
HOw do I get the metal filter off, I can't remember and I cannot find my book
The crescent tool has two protruding metal “nubs”. After you open the juicer so you can see the mesh basket that turns around, and a flat grating disc that has two holes that match those nubs. Insert the nubs into the holes and turn counter-clockwise to loosen the disc. (you’ll have to hold the plastic edge of the mesh basket so it doesn’t turn). Once it’s loose, keep turning it until it comes off. You can then remove the disc, the basket and part containing the spout to clean them. Just reverse the process to remount the parts, making sure not to overtighten the disc.
Jack LaLanne power juicer 250 no longer works.
The stainless bar should be on the correct slots on top of the juicer. It has a safety switch on those bars. Smell the motor from under the juicer, it should not smell like burnt. Press hard on the switch, it might be loose.
1helpful
Jack Lalanne Power Juicer model cl-03AP
Hi - You can download the manual from the link underlined in blue below:
Power Juicer
Please update the question & let us know if the information given was useful to you - Good Luck!
Top Omega Juicers Experts
john h
ADMIN Andrew
ADMIN Andrew
Aron
Are you an Omega Juicer Expert? Answer questions, earn points and help others
