It's a problem in the transmission. Most likely a snap ring has broke. This ring keeps the clutches compressed and in position. Problem is you have to pull the transmission and disassemble the entire inside of it to get to the ring.
The only small lock ring that I can think of is the one that holds the throw out bearing on the end of teh clutch release rod. it's a vrery tiny O-ring, about an 1/8" indiameter. Everything is alright unless you pull your clutcth and you pull the clutch release rod out. Then you have to pull the other side of the transmission case to put the new bearing back and trhrust plae,
Did your clutch pulley use the upper One-Way Bearing ring? What are the first two digits of your Serial Number of the machine? What is the history of the Clutch install? Did the unbalance issue continue right away with the new Clutch Install? How much rust did you find on the Clutch Pulley and the Upper One-Way Roller clutches bearing ring if used?Any Pic’s of the old Clutch Pulley? If you shut off the water source valves to the machine and release the top the washer so you can lift the washer top and observe the wash basket rotating CCW at 50 RPM during the water fill part of the wash cycle. Start a quick wash cycle and lift the washer top to observe the wash basket rotation CCW. The wash Basket will rotate CCW at 50 RPM. You can go into Service Mode and observe on the LED console FAV6800A machine. Not sure about the FAV9800A LCD flavor of the machine. Do the tumblers rotate slightly during the water fill part of the cycle? The machine may error out with NF for No Fill don’t worry about that I just want to determine if the tumblers are rotating during the CCW/Spin direction of the wash basket.You may have to put some dry laundry in the wash basket to help with the observation.
you might have your engine hydro locked. easy solution to this. empty your gas tank, take your glow plug out, turn your truck up-side-down and crank it over a few times. put everything back and you should be ready to play again. what happened is you probably flooded your engine. another possibility is your battery for your EZ-Start isn't charged enough, so before you go through the hassle of the above steps, check your battery first.
Is the clutch bell turning the spur gear? Have you checked the slipper clutch to make sure it has not loosened? If both of these check out it could be something broken inside the transmission.
