Hi and welcome to FixYa,
Sorry but there could be a number of possibilities and the best diagnosis would be to perform voltage checks of critical boards and compare with known readings. Common problems could be as simple as cold solder or loose connections, thermal fuse of the cooling fan or the light engine in some models not necessarily what you have.
This of course would require a fair familiarity of electronic
components/circuitry and safety procedures, use of a DVM and a
soldering iron. It would be to your added advantage access to a
service
manual or at the very least a
schematic diagram with voltage
readings.Should you be uncomfortable performing a DIY (
do-it-yourself),
perhaps your best bet would then be to seek the services of a qualified
professional.
Good luck and Thank you for using FixYa.
