Want to fill radiator
SOURCE: john deere 420 trouble starting getting gas and
The engine needs air, so be sure the air filter is clean. If it is not, replace it.
The engine needs spark. Replace the spark plug and be sure that the battery has a complete charge.
The engine needs good fuel so be sure the gas is newly purchased, not gas that has been sitting around for months.
SOURCE: where is the hood release for the 3320
Below the bottom of the hood you will find two metal tabs,push down on either one to release the hood.You will have to release the grill guard pin and roll it forward before the hood will open all the way[if it has a loader on the tractor].Under the hood and to the left of the battery is the prop rod to hold it up.Hope this is helpful.
SOURCE: have a john deere lawn tractor. Blade will not
Check both belts on deck. Check if the clutch is clicking in. If not it will most likely need a new pto switch.
Sam
SOURCE: john deere 300 garden tractor hydrostatic drive will not work
check two things, make sure the by-pass rod is pushed all the way in and the drive belt from the engine to the rear end (tranaxle). If both check out ok do not attempt to service the tranaxle at home. have thet serviced by a dealer.
