No problem just looking at washers and want to know which one to buy Saw a gallery front loader and wanted to know more about it. It is used and I do not know the age of it. Wanted to know how long gallery washers have been made.
Open the top of the machine (look behind the top for several screws to remove) and slide it back to release from the cabinet. This should give you access to the screws that hold the vane in place. Hope this helps!
Unfortunately, only some model Dryer doors are able to be changed, not the washer doors. You can find out the Model of your dryer and I can let you know if indeed you dryer door swing can be changed or not. The other solution is to stack the set to not have the doors impede loading and unloading if your models have a stacking kit available for them.
I hope this helps! Good luck!
Just get the model number of your machine and buy a new one, you cannot fix it by trying to assemble again, spring had pressure, it may hurt you if you try to fix it, It is much advisableto replace it with new one
It could be multiple problems, if so it's more than one of the below, it would be cheaper to buy a new unit.
Start by removing the front panel and check the belt and idler pulley/tensioner. Look for wear in both and make sure there isn't too much play (it should only move about a 1/2 inch when pushed on it's longest stretch. While you have the front open, inspect the pulley for damage or excessive play.
Another cause could be the transmission (it's just above the pulley). Look for fluid/oil leaks and/or rust. A bad oil leak can cause the transmission to seize up. If you notice rust accumulated on the transmission assembly, you probably have a bad seal. Water could have gotten in there causing it to fail. A damaged transmission needs to be replaced, repair parts are not available.
The cycling problem sounds like a faulty timer. Test it by advancing the dial and make sure the correct cycles are starting/stopping. This part can be replaced with a few simple tools.
As always, make sure you disconnect the power before doing any service.
I don't think you can on a front loader washer.. on your dryer you can see how they have screw covers for interchanging, but on washer there are none.. sorry.. good luck..
hate my duet sport also! You cant presoak in this machine, very little water to wash with, very noisy, and everything stinks when it comes out of washer. Mine also smelled like mold but i figured out if you pull out the little tray that holds the detergent it is filled with stinky black mold. would never buy again
not really front loaders have top loaders beat all the way but stay away from admiral and maytag .a front loader will wash your clothes using the soap that your top load failed to get out if i may suggest buy a frigidaire with a mechanical timer not electronic control more junk on them more to fail the best combo in my mind is a frigidaire front loader and whirlpool dryer front loaders use 2/3 less water 2/3 less soap and will get your clothes twice as clean they have no transmissions and are direct drive the most common promblems with them is having to clean out the pumps where people leave stuff in their pockets also you need to buy soap thats for front loaders its called high effincey or he soap and they will get your clothes make sure you read the installation guide and remove ALL the shipping braces
