Martin Archery Bobcat Youth Compound Bow Kit Logo
A
Anonymous Posted on Mar 08, 2014
Arrows flying irractic when shot - Martin Archery Bobcat Youth Compound Bow Kit
Kardoc
Level 3:
Top Expert:
  • Martin Archery Master 7,503 Answers
  • Posted on Jul 02, 2019
Kardoc
Level 3:
Top Expert:
Answers
7503
Questions
0
Helped
2759695
Points
58323
Check your arrow rest.
2answers
Arrows fly different directions when shot on brand new bow
Barnett says it all. terrible quality problems lately. Could be anything. I suggest return it and for youth bows the atomic bow is the best at best price. Made by bowtech diamond line.
Irractic idle when in gear and ac is on
Sounds like a miss - is the check engine light on too ?
2answers
Let me know the control keys for both bat&bowled of EA sports 2007
For bat......S=normal shot
D=front foot shot
W=backfoot shot
S+Shift=Six hit shot
D+Shift=Advanced shot
W+Shift=backfoot shot
D=Running(works only after shot is played)
A=Cancel run
W=Dive
How to format my memory stick in sony Cyber shot DSC750
Hi the first thing you do to format your memory stick is you need to Insert the memory stick on the camera because it is formatted in the camera.On the camera,you need to turn the MODE DIAL to the SETUP position.And then turn on the camera. By using the CONTROL BUTTON, kindly press the DOWN ARROW button to select MEMORY STICK TOOL.And press the center of the CONTROL BUTTON.Kindly press the UP ARROW or DOWN ARROW button to select FORMAT.After that press the RIGHT ARROW button.Kindly press the UP ARROW or DOWN ARROW button to select OK and press the center of the CONTROL BUTTON.
Hopefully those instructions will help you get going again with your Sony digital camera. Good luck!
1helpful
How to format my sony cyber shot DSC750?
5helpful
I have a power shot pro stapler model # 8000 , what size staple do I need?
You've got a good bit of choice, it will handle any of the following. 1/4-Inch thru 9/16-Inch heavy duty PowerShot and Arrow T50 staples and 9/16-Inch PowerShot brad nails
1helpful
What are the symptoms of te welder being too far
Irractic welding, hot leads, and voltage drops. You need to size your welding leads accordingly.
How to set language to english on sony cyber shot dsc w70
Push the button below the word 'menu'. The word 'setup' should appear. If not press the right arrow on the advance button located on the dial below the menu button. Then you should see a column of icons that look like cameras(?).
Push the down arrow on the same dial. Move down to the third one and then push the right arrow. You should see the word 'language'. Highlight that and push the right arrow again. You will see a list of language options. Highlight the one you want and then press the center button or left arrow to back out of this.
Top Martin Archery Archery Experts
Kardoc
ADMIN Andrew
ADMIN Andrew
Are you a Martin Archery Archery Expert? Answer questions, earn points and help others
