Have scanned about 500 slides. Suddenly in the middle of a rack, the time to scan one slide increased from 3-4 minutes to about 20 minutes? And I can clearly hear the scan sequence ticking much slower than before. I did not change any settings. What can be the problem and how to fix it? Any ideas? I already tried to turn off the scanner and the computer and restart everything. Did not change anything... Thanks
SOURCE: I am trying to install my Braun multimag slide
Driver available here http://www.latestdriversupdate.com/driver/36681.html
I had a used SlideScan 4000 that I tinkered with trying to get working for 2 years with several computers, drivers from the web & firmware updates. It would scan a few slides then freeze. It seemed to depend on the memory, as I could scan 2-3 slides on low resolution before freezing, but stopped half way through the first slide on high resolution. I finally found that I had to go into Device Manager (I'm on Windows 7 - Ultimate) and delete all other imaging devices (well I think I was able to leave the computer's web cam on) to enable the device driver to load properly. I installed Cyberview X - which installs the driver but I am using Vuescan for my slides. I recall my dad having a similar problem getting another scanner to work on his computer. Apparently it is a common problem to have conflicts with scanner drivers if you have more than one on your computer.
