I have 4 Artslon bell cordless bells/chimes in the house, but after 18 months the bell push has failed. Everything has been tried, new batteries, etc., etc., but it seems to have failed in the circuitry. I have tried to find a replacement but they do not seem to be available any more. The Artslon mains plug-in bells/chimes do not need a specific code setting to work so the theory seems to be that there are other bell pushes that will work with these. Can you please help with this other than buying another set of 4 bells/chimes and a bell push to cover all areas of the house which will be expensive. I will be most grateful for your assistance. Thank you. Michael
SOURCE: Get error code #4 & furnace won't start up
A pressure switch is a safety, which in this case is being used to verify that your furnace is drafting properly. Yours in particular is sticking in the closed position even after the call for heat is satisfied. The control board checks to make sure the switch is open the next time there is a call for heat, and when it sees that the pressure switch is already closed even before the draft inducer motor comes on, it knows there is a problem....hence the error code. When you are rapping on the furnace, it is causing the contacts to open, eventhough you're not tapping on the pressure switch itself. Usually you will see a rubber hose attached to the pressure switch and 2 or three wires depending on what type of switch it is.
I hope this helps!
SOURCE: Hi there,
there should be a name or brand to this unit . look it up on the internet , they should have a support number that could help you
Testimonial: "Thanks ... I actually googled Rinnai and managed to find the manual. "
SOURCE: Hi i have a new DeLonghi Dragon 3 heater. The
This is from the instruction manual online: To set the heating periods proceed in the following manner: - Check the time by your watch. Supposing it is 10.00 a.m. turn the numbered dial of the time-clock in a clockwise direction until the number 10 coincides with the reference mark s on the time-clock. Set the time period during which you wish the appliance to work by pushing the notches towards the centre. Each notch corresponds to a period of 15 minutes. At this point sections will be visible corresponding to the working periods. Set in this way the radiator will function automatically every day during the set period. (Important: the plug must remain connected to power supply). - To change the programmed time period, just bring back the black notches to their original position and set the new working periods required. - If you wish the appliance to function without programmed working periods push all the notches towards the centre. In this case, to turn the appliance off totally the plug must be pulled
out apart from switching off, so as to avoid unnecessary working of the timer.
bell push dose not work
the bell dose not work
bell push dose not work the chime
