Every time I plug in my Whirlpool Calypso washer, it blows the GFCI. tried several outlets on different circuit breakers with the same result. Other appliances work when plugged in to the same GFCI.
At a guess, you have a leak or a damaged seal/insulation around some switch/wire in the washer. Assuming a GFCI (ground fault circuit interrupt) breaker, some wiring is getting damp at the end of the washer cycle and triggering the breaker when you try to run a second load. This wiring dries out overnight and thus doesn't trip the breaker on the first load.
To check if the GFCI breaker/outlet, try plugging the washer into a outlet on a different breaker. Use an indoor/outdoor rated extension cord appropriate for the electrical load. If the second circuit is GFCI-protected and the breaker trips, check the machine for leaks or damaged insulation on a wire or several wires. If the lid switch is getting damp, that would stop the machine. The leak or damaged area is probably fairly small since it takes the full cycle to get the breaker to trip. If the breaker doesn't trip, replace the breaker or outlet. Get an electrician to do the replacement if you aren't comfortable doing this.
Alternatively, the washer is overheating and cooling down overnight. I've heard of the inlet water solenoids tripping a circuit breaker when the inlet water lines have clogged screens. Similarly, if the motor is overheating at the spin cycle, you might see this. You can try using a meter to see if the current draw changes during the washer cycle. Alternatively, try start the second load an hour or several hours after the first (just less than the 24 hour pattern you've tested).
The washer tripped the breaker once and OR after the breaker was reset it ran additional loads with no problem then it tripped the breaker again.
Intermittent problems are always difficult to diagnose because the problem usually doesn't occur when you're making the checks.
If the washer ran additional loads the problem will not be an electrical short with one of the washer parts. If the lid switch had a short it wouldn't run additional loads.
if the additional loads used the same cycle as previously. A timer can have an internal short that might trip the breaker in heavy duty cycle but not the permanent press cycle.
If you have access to a clamp on amp meter, see the image below, then you can check the amp draw of the washer. The washer normally will draw about 10-15 amps at start up and about 5-8 amps while running. The house breaker for you washer should be rated at 20 amps.
If the washer is running and drawing less than 20 amps and the breaker trips then if can be a weak house breaker.
Mid cycle the washer is most likely draining or spinning and if the bearing or pump locks up then the washer may draw additional amps to try to start and trip the breaker.
The key to this problem is what the amp draw of the washer is when the house breaker trips.
To narrow this problem down, there are three places that could be causing the ( outlet) GFCI to trip, a malfunction in the washing machine, a problem with the downstream wiring (aka load side of the GFCI-other items connected on same circuit), or the GFCI outlet itself. If there isn't anything downstream, then plugging the washing machine into another GFCI outlet, or simply swapping out the outlet for a known good GFCI outlet, will identify if the outlet itself is faulty.
If the outlet trips when the washing machine isn't running and isn't even plugged in, then there's a fault in the wiring on the load side of the GFCI outlet.
If the issue is neither of the above, then running the washing machine and monitoring to see which step is occurring when the trip happens will isolate what part of the washing machine may be leaking current to a ground. It could be a certain water level, a motor being engaged, a transition step in the controller, etc
Beware some techs believe that most Washing machines or any other motor should not be on a GFCI! Should be a dedicated single receptacle. If there are other outlets on the washer GFCI, replace that GFCI with a single receptacle and put the GFCI on the next jump in order to protect other outlets.
Another item to check is ur lid switch which may have gotten moister inside and created a short_ or broken open and the rubber seal dried out over time, and the switch assembly will be exposed. water can splash onto the assembly, somehow causing the GFCI to trip. In any event, if you are having trouble with your washing machine stopping mid-cycle for any reason, test and replacing the lid switchis probably a worthwhile idea, as it is cheap and easy to replace.
By the way my advice is free cuz God is good!
If the washer ran additional loads the problem will not be an electrical short with one of the washer parts. If the lid switch had a short it wouldn't run the additional loads.
You don't say if the additional loads used the same cycle as previously. A timer can have an internal short that might trip the breaker in heavy duty cycle but not the permanent press cycle.
Need more info:
What fuse? the one at the end of the cord on the pressure washer? Or the circuit breaker on your house?
If it is the one on the cord it may have gone bad. To test replace it with normal plug (non-GFI) and plug it into an outdoor or bathroom GFCI (GFI) outlet. If it still trips that outlet then there is a ground fault in the device which may be minor or major.
If it is a home circuit breaker remember that electric pressure washers use a lot of power - typically 1500 watts. If anything else is plugged in it can trip the house circuit breaker.
why do you have your dishwasher plugged into a GFCI? I have never heard of this being a requirement. Do you have a GFCI receptacle or circuit breaker? The receptacles are notorious for failing after a few years.
Usually the washer circuit is a seperate 20A circuit. The lights would be on a different circuit usually 15A. Check your panel and see if there is a 20 breaker tripped. Hopefully your panel is labeled (or it should be) Are you saying this tripped while using the extension cord? Another possibility is that it is controlled by a GFCI outlet. You can connect additional receptacles to a GFCI outlet to protect them. Check to see if you have a GFCI receptacle tripped (in garage, bathrrom etc)
I ran into this problem with a washer this summer. the gfi breaker needs to be replaced. it is weak and trips easily. if you can run an extension cord to an outlet without the gfi andrun your washer, you probably will not have any issues. that is what I found with the washer this summer. when it was plugged into the gfi, itwould trip. but when I had it plugged into a regular outlet, it was fine. Joe
