Franklin Industries FBC360D Beverage Cooler Logo
A
Anonymous Posted on Mar 06, 2014
Shrill whistling noise
Intermittent high pitched whistle sometimes stopped by shifting a bottle....Could this be fixed be leveling? Or? Had to empty and unplug because it became too annoying.
2answers
Why does my Rigid shop vac make a high pitched whistle with a long hose on it but not a short hose?
The high pitched whistle that you are hearing from your Rigid shop vac with a long hose may be due to several reasons. Here are some possible causes:
  1. Airflow restriction: When you use a longer hose with your shop vac, it increases the airflow resistance, which can cause a whistling noise. This is because the motor has to work harder to maintain suction, and the increased resistance can cause turbulence in the airflow, creating the whistling sound.
  2. Hose size: The size of the hose can also affect the whistling noise. A smaller diameter hose can increase airflow resistance, which can cause the same issue as a longer hose.
  3. Clogs or blockages: If there are clogs or blockages in the hose, this can also cause the whistling noise. Check the hose and attachments for any obstructions, and remove them if necessary.
  4. Vacuum motor issue: In some cases, the whistling noise may be due to a problem with the vacuum motor itself. This could be caused by a damaged impeller, a loose fan blade, or other issues with the motor.
To fix the issue, you can try the following:
  1. Shorten the hose: If possible, try using a shorter hose to see if the whistling noise goes away. A shorter hose will reduce the airflow resistance and may help to eliminate the noise.
  2. Check for blockages: Inspect the hose and attachments for any clogs or blockages. Remove any obstructions that you find.
  3. Clean or replace the filter: If the vacuum filter is dirty, this can cause airflow resistance and make the motor work harder, leading to the whistling noise. Clean or replace the filter as necessary.
  4. Check the vacuum motor: If none of the above solutions work, you may need to inspect the vacuum motor for any issues. If you are not comfortable doing this yourself, you can take the shop vac to a professional for repair.
Is a high pitched whistling sound at idle a vacuum leak or what?
hissing vacuum leak at idle, louder with open throttle ...
? 1:43
https://www.youtube.com/watch?v=tFoybr865n4
Jun 27, 2010 - Uploaded by fenixus
hissing vacuum leak at idle, louder with open throttle ... i know that my camera is poor and microphone suppresses high pitch ...Hi, my kia picanto engine also sound hissing/humming duringidling with open throttle. ... Loud whistling noise 2000 jeep wrangler 4.0l - Duration: 4:01. by Nasrac72 16,158 views.Missing: vt750c
A Whistle or metal sound with firing... - Honda Shadow Forums ...
www.hondashadow.net > ... > Technical Discussion
Jul 11, 2008 - ... under load (accelerating), that there is a small whistle or even 'tap on metal' high pitch sound ... Pics of my 2008 Shadow Aero 750 (VT750C ... loose bolt vibrating
Feb 29, 2012
High pitch whine
Jul 21, 2009
More results from www.hondashadow.net
2answers
Emits high pitched whistling after unit runs for 30 minutes
Sounds to me like the bearings are going bad in the motor. The hotter it gets the grease breaks down and the squealing starts.
If you need further help, reach me via phone at https://www.6ya.com/expert/thomas_092728000e6acb79
Rough idling, high pitch whistling sound
Sounds like a vacuum leak. Best way to locate is with a spray bottle and some water. Spray in the area where the known noise is. You will have located your leak when the water sounds like someone drinking soda from the bottom of an empty cup with a straw. Good luck.
2answers
2004 honda odyssey making whistle noise
I know this original question was written quite a few months back but I was wondering if you ever found out what the high pitch sound was. I just purchased a used 2005 Honda Odyssey and it is doing the exact same thing. Any advice?
1helpful
2004 77000 Sonata emits a shrill whistle when moving forward
mmmhhmmm there can be 2 problems #1- your pulleys need to be replaced or #2 u need new belts
hope this helps
2answers
High pitched whistle noise coming from engine
it sounds to me like it is a blower motor not the engine.(heater fan)
1helpful
3answers
High pitch whistling noise in engine compartment of 2005 envoy
There may be a small hole or cut in a vacum line or possibly just loose. Also make sure the air filter box and the big hose to it are secure and clamps etc are tight. Pulleys and belts can make a high pitch sound also.
Occasional 'whistling/whining' from back of TV
I wonder if there is enough air circulating around your equipment?? My DVD recorder makes a sound unless I open the doors on the cabinet that contains all of my equipment. The cable company says it is a fan to cool down the units.
Top Franklin Industries Refrigerators Experts
ZJ Limited
ZJ Limited
john h
Are you a Franklin Industries Refrigerator Expert? Answer questions, earn points and help others
