The front panel reads 05F and won't continue with the cycle. It starts to wash and the clothes are wet and it then just stops and the 05 F flashes on the control panel
all front loaders will not go into high spped spin if there is water in the tub.You should first remove the bottom panel and check the water pump for blockage.Some units have a sscrew style filter to catch debris befor it enters the pump impellor.when you unscrew the filter make sure you have a wet vac handy.
Front load washers won't fill if the door is not closed and locked. Listen for the door locking when starting a cycle, then pull on the door to make sure the door is closed and locked.
Delayed Start Feature
Some washers have a delay prior to filling, where the electronic control is checking the dispenser function. This is Normal.
Flashing Lights or Error Code on Display
When there is a filling issue, the washer may shut off and display one of the following codes: LF, LE, nF, IE, FH, E10 or F20.
If the washer is displaying one of the above error codes, then do the hard reset procedure listed below.
If the appliance is not accepting input from the control panel, follow the steps below to reset the control:
Unplug or turn the circuit breaker off for 30 seconds.
Plug the power cord into the wall outlet or turn the breaker back on and wait 30 seconds.
Press the Pause / Cancel / Stop button twice to clear the display.
Start a short cycle, to check operation of the appliance, by selecting a cycle and pressing and holding the start button until the appliance starts.
to much detergent...with theses unit you must use he or low suddsing detergent..take half the wet soapy clothes out then start unit..sud level must fall...
sounds as if you have a drain issue, most common cause of fault is theres something stuck in the pump housing. remove the lower acess panel(3 screws along the bottom of the forn of unit) youll gain acess to the pump housing, remove the large cover to the "button trap" by uncscrewimg the cover, it will be righthin front of you in the center of machine when cover removed, im sure youll find your blockage within there
check the pump filter and if necessary clean it up.
if you stop the programme and hold the start/ pause button for 3-5 sec the programme will cancelled and the drain will work.
if you hear a slow noise from the pump it may be blocked with external objects from your clouthes pocket,
Check that the filter is not clogged. Disconnect AC FIRST........****** open the bottom access panel , (3 screws on bottom lip) remove panel open the large filter in the center, very apparent be prepared for water, have mops ,buckets rags, pans ready. clean and remove all debris. see if anything when up into the small pump area too. spin the pump propeller and make sure it spins free. if you find nothing but water then the main large hose in the center may be clogged, that will take some work to disengage the clips and to reinstall.
