I have 2006 Peterbilt, C13 Cat engine. I need to know what fault code 286-7 is
Caterpillar Fault Codes look here Caterpillar Fault Codes
SOURCE: fault code po420 ; is problem sensors or is it the cat conv
The only thing that will set this code is the catalytic converter or the oxygen sensor behind it. Way to tell if it is the sensor is to monitor voltage reading with scan tool and see if it is fluctuating the same as the upstream oxygen sensor. If it is the converter is "free flowing" and will have to be replaced. If the sensor is "flatlined" then it is most likely bad and setting the code.
SOURCE: no fuel to Cat C 9 engine,
there is a ckaek valve on the back of the cylinder head on fuel return line, they often fail.
SOURCE: need list of fault codes for gm firebird 2000.
Visit http://www.troublecodes.net/GM/
Good luck and rate this solution.
SOURCE: 2006 Toyota RAV4, 3.5L V6 Check engine
I am having a multiple cylinder misfire on my 2006 Toyota RAV4 with the 3.5L V6. Every cylinder is reporting a mifire. Each cylinder has it's own coil. I highly doubt that all 6 coils went bad at once. Does anyone have any idea what my be causing this?? Is that the problem you two are having?
SOURCE: vw lupo engine code fault 17852 this code is not
It is a manufacturers fault code, it means implausable signal from G212
In English that means replace EGR valve :o)
