What does EP mean on the temperature display of a infrared sauna room (2 persons)
What does EP ON THE SAUNA MEAN ?
Posted on Jan 19, 2020
My 2 person zen awakening infrared sauna. The wire from the fuse going to the board with all of the wires attached has burned up. What to do?
possible loose wire caused overheating or motor or heater element overheated or shorted or bad ground also make sure power ok under power will overheat
Nov 11, 2017 | Pool & Spa
Heilsa Pellet Stove Manufacturers Information
pellet stove tp440 Pool & Spa Heaters Questions & Answers ...
www.fixya.com > Forum > Tags > pellet stove tp440
Pool & Spa Heaters pellet stove tp440 questions and answers. ... for a manual orinformation on this stove it is an older stove we just don't know how old. ... heilsa pellet stove model qcps-28000 my pellet stove is smoking how to change ...
General Infrared Sauna Heilsa Sauna Supplier, Find Best ...
www.alibaba.com/general-infrared-sauna-heilsa-sauna-suppliers.html
Suppliers who can match your search. .... Outdoor Spa,Sauna Room,Jacuzzi,Swimming Pool,Sand Filter .... Infrared sauna room,Portable steam sauna,Infraredheater,Pellet stove,Clothes dryer ..... updates on topics such as trending hot products, buying requests and supplier information - sent directly to your email inbox!
Good Quality Far Infrared Sauna Supplier, Find Best Good ...
www.alibaba.com/good-quality-far-infrared-sauna-suppliers.html
Suppliers > .... Outdoor Spa,Sauna Room,Jacuzzi,Swimming Pool,Sand Filter ...Infrared sauna room,Portable steam sauna,Infrared heater,Pellet stove,Clothes dryer ...compare heilsa infrared sauna with good infrared sauna accessories ..... buying requests and supplier information - sent directly to your email inbox!
Jan 06, 2016 | Pool & Spa
How do I get the back heaters to turn on, I would like to find a manual for my sauna
Natasha, honey, I don't know your make/model; but go to their web site and download it.
Oct 13, 2014 | Eacon Far-Infrared Sauna Cabin - 3 Person
Infrared sauna room (2 persons) Does anybody know what EP stands for or/means on the temperature control panel???
check to see if filters are clean if so see if recirculation pump is working if so check heater fuses if blown probably bad heater element
Mar 06, 2014 | Blue Wave Coronado -2 Person Infrared...
Sauna wont get hot enough
When I'm in a traditional sauna like this, I expect the temperature to be between 70 and 90C so that's what I assume you are trying to reach. There could be several reasons for this so make sure each point is checked:
1. Stating the obvious, to increase the temperature inside the sauna, you'll have to ladle water onto the hot sauna stones.
2. Maybe the insulation within your sauna isn't good enough and heat is escaping.
3. Your sauna room could be too big for this heater to heat properly.
4. Maybe the element on the heater isn't performing properly and needs to be replaced.
These were some pointers which Di Vapor gave as possible reasons for lack of heat.
Sauna Electric Heaters Spares
Feb 15, 2014 | Amerec 4.5KW Heater w/ Built-in Dial...
The big infared panel does not work, what can i do?
be looking for fuses or connections .. does it have power??
Dec 20, 2013 | Dynamic Sauna 1-2 Person Far Infrared...
What is a sauna?
"A sauna is a small room or house designed as a place to experience dry or wet heat sessions, or an establishment with one or more of these and auxiliary facilities.
A sauna session can be a social affair in which the participants disrobe and sit or recline in temperatures typically between 70 degrees C (158 degrees F) and 100 degrees C (212 degrees F). This induces relaxation and promotes sweating.
Saunas can be divided into two basic styles: conventional saunas that warm the air or infrared saunas that warm objects. Infrared saunas may use various materials in their heating area such as charcoal, active carbon fibers, and other materials."
Oct 03, 2013 | Pool & Spa
Sauna
I think you have the wrong category.
Apr 29, 2013 | Computers & Internet
I have problems with the power of mij sauna. were
Did you get an answer to your question. I am also looking for s126smd3 to buy.
Mar 11, 2011 | RTO 1 Person Ceramic Heater Far Infrared...
Heating & Cooling Logo
182 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Marvin
Marvin
john h
