EP shows up on the temparture screen,and the sauna dosent seem to be heating up
First verify that all wires are connected properly. If they are then it is either that your temp sensor has failed, or the cable is damaged, or you need to replace your computer board or have someone like our company rebuild it for you.
Please email me directly at [email protected] if you determine that you need the board repaired.
Check to see if filters are clean if so see if recirculation pump is working if so check heater fuses if blown probably bad heater element
