Have you checked the power cord is firmly connected to the power source (wall plug? or wherever) and have you checked the cord connection into the tv?
Pull them off and reconnect
If the red (standby) light does not come on, then you have an internal problem and these cant be fixed without opening up the tv. Dont do it- it has to go to the dealer
Testimonial: "I had already done that. It didn't work. I just hate paying someone to fix it. I paid a lot for the t.v. and it should have lasted. I won't be buying Sony anymore. I have not had problems with other brands."
SOURCE: sony tv KDF55WF655
I had the same problem. The sound and picture went off for about one minute and the green power light flashed green. Then the TV came back on. It sometimes stayed on for hours and sometimes went off again in a few minutes. The TV is just over 3 years old. Had the service people out and the problem was the bulb. It cost $420.00 to fix. He said our bulb lasted twice the average life. I wish that I had known this since it is a simple fix and the cost of the bulb on line is under $200.00.
Ken
SOURCE: sony wega kdl-l32mrx1 3 yrs
The solution to this problem was the Relay RY6001 replacement. I was able to find a suitable part from CPC check out:-
http://cpc.farnell.com/schrack-components/rtb74005/relay-pcb-spco-5vdc/dp/SW02588
for the details. The part fitted Ok when one of the pins is cut off. You do not need this pin so it is OK.
I have a full set of fix it photos if anyone needs them. It took about 40 mins to strip, replace and re-biuld the TV - there are loads of screws to get at the PCB and then you have to put them all back!!
Thanks again to mgnut for all the info.
SOURCE: Mitsubishi TV green flashing timer light after power outage.
You will need to cahnge the capacitors on the DM board, very common problem. The V21 V19 DM repair kit at the following link contains the replacement capacitors and detailed instructions. Its listed under the repair kits catagory at the following link.
http://servicemanuals.vstore.ca/
SOURCE: Sony bravia KDF-E50A12U rear projecion tv wont turn on
Hi it sounds like it could be an issue with board that powers the lamp ,it's called the ballast.When you put a new lamp in the ballast has to provide more power ,when it starts to go weak it will not light up.Sometimes you can put your old lamp in and will work fine.Try partstore.com they might have it right there.Hvae a blessed one!
SOURCE: Sony Bravia KDS-60A3000 won't power up 9 flashing red power light
According to other posts I have read (I have same problem) there is no power getting to the fans. They recommend re-seating the fan harness again as it might have come loose or might have dust etc., in it.
I have no idea how to do this yet but that is what the trouble-shooting guide says.
