SOURCE: Will not start
To start unplug the machine power cord for ten minutes or longer, this will drain power from the machine and reset the electronic controls.
If this does not fix the problem check the following:
Check that the water supply at the back are opened and taking water into the machine.
Check that the door latch sensor is not stuck, and that door is well closed that is a frequent problem.
Check the drain hose and the drain lines, ensure that there is no blockage in there.
If this still does not work, then the machine has a faulty part that must be replaced, and must be tested by a qualified technician.
Use the phone number listed on the owner manual if you need to contact the repair service.
SOURCE: bosch maxx wfl 1300 washing machine that wont start.
hello could be brushes on the motor. there are 2 black clips that sit on the motor after time these whare down just slide them out and slide new ones in good luck
shaun
SOURCE: My Bosch WFL 1220 MAXX F/L washing machine stops during a cycle
The diagnostics are finding a proble. Usually a time out on the fill or empty. Check water supply is clear and that the drain filter is clean
SOURCE: Bosch Maxx WFL 2061 motor starts running and then stops
Hi ! I have problem with my Bosch Washer wfl 2061 .. It was running till stoped to
realease drain water out... But no drain water come out.. I have checked drain water host... Nothing thaere.. Water was still in the drum Tank... Whoever knows this problem , please kindly suggest or help me to do something.. Thanks.. Peace [email protected] , [email protected]
