Xerox WorkCentre 3220 Logo
p
popa marius Posted on Mar 04, 2014
PCL6 ERROR - Imcomplete Session by time out - Xerox WorkCentre 3220
shadapar
Level 1:
Habit-Forming:
New Friend:
  • Contributor 22 Answers
  • Posted on May 04, 2014
shadapar
Contributor
Level 1:
Habit-Forming:
New Friend:
Answers
22
Questions
0
Helped
32211
Points
24
Update your firmware, follow the steps included in the zip available at www.xerox.com. Or switch to the PS driver which most xerox's prefer. Also if its a .pdf file. Click advanced and choose, print as image.
Incomplete session by time out
Hi Michael,
What are the PCL Drivers that you are using for the printer. Normally, Changing/installing different PCL drivers fix the issue.
For Ex, If you are using PCL6 drivers, try PCL5e
Regards,Suhail
2answers
Can't find sharp ar-bc320 driver for 64bit, there's only PCL5 driver which won't work, we need PCL6 driver for this model.
Sharp does not natively support or provide a PCL6 driver for this device. That being said, another possible workaround to provide you with a PCL6 driver for this is to try the HP Universal Print Driver for Windows PCL6 x64bit. This driver simply prints direct to the IP address that the printer uses on the network. You may sacrifice a few special features of the device using this driver, but I've had excellent success with it and recommend trying it.
Here's a link to the driver:
http://hp.driversdown.com/hp-drivers-download/HP-Universal-Print-Driver-for-Windows-PCL6-x64_18967.shtml
Hope this helps!
I am getting a pcl xl error I/O Subsystem: InputReadError Error: ReadImage Operator: ReadImage Position : 14 Please help this only happens when tyring to print a PDF from Adobe 9.
You didn't say what kind of printer you have.
Sounds like a driver problem.
Go to the manufacturers web site and download the latest drivers for your printer.
If you were using the PCL6 driver, try installing the PCL5 driver. If you were using the PCL5, try using the PCL6.
1helpful
Error code PCL6 incomplete session by time out
That is normally caused by firmware corruption. You can go to Xerox.com, click on support and drivers, then in the search box enter pe120, then go to drivers and downloads and download the newest machine firmware . There are directions on how to install the firmware , make sure you follow them step by step. It's pretty easy and should resolve your problem.
4helpful
Xerox M15 PCL6 error
I would go to the xerox website and try downloading the PCL5e driver. It works just as well and even better in most cases. I hope this helps.
4helpful
2answers
Pcl xl error warning: Illegal media source
Some people have issues with the PCL6 driver this causes pcl xl error like this to print. Change your driver from the PCL6 driver to the PCL5 driver. If you don't have the software you can down load it from HP at: http://welcome.hp.com/country/us/en/support.html
Thanks...V
Does PCL6 support duplex printing?
This is gona be a helpful website for you
http://search.lexmark.com/printer/US/en/13D0000
Top Xerox Office Equipment & Supplies Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
