How do I close the CC? There is no CC button the remote. We are using Dish. There are no CC's on the Samsung DVD player, only the tv. Thank you very much
The CC (closed caption) option is usually set (on or off) from your TV's menu screen. From your remote (or TV), select the Menu, then look for Settings, and when you see CC .... you can turn it off. If you provide the TV model, more specific instructions can be provided.
Testimonial: "Thank you LP for your quick response to my problem. The CC has been removed."
What is the TV model ?
Toshiba CT-90251 Thank you.
The CC has been removed. Thank you!
SOURCE: closed captioning
I am sorry you don't. You will need the original remote. I have enclosed a link where you can see the original remote and order one if you want to. If you see the picture, there is a caption button on the remote to turn on and off the closed captions Good Luck. Here is the link http://www.remotes.com/remotes/servlet/rs?a=gmi&smodel=DS24424&brand_pn=SANYO_DS24424&mode=large&uid=11872683567810
SOURCE: Closed Caption won't turn off
The following should solve your problem if you have a comcast digital cable box and possibly for others.
Hey, it's worth a shot!
Turn the TV Power on and cable box power off.
Press the MENU button on the front of the cable box.
Scroll down to the caption item on the menu and toggle it to "disabled"
Press the menu button again to close.
Hope this helps!
SOURCE: JVC model LT42EM59 closed captioning now gone
checked with satellite company and they have admited this is an intermittant problem with them and they will be creating software to download to correct
SOURCE: no remote how to turn off cc
You might try a Magnavox brand universal remote. Get one with a "menu" button. Often they give nearly complete control on a Magnavox brand TV. Otherwise, the only real solution is to purchase the exact original remote. There are many vendors on the Internet selling replacements, but often the costs are ridiculous.
Thank you. No luck so far. It is a 2006 Toshiba CT-90251
Thank you. The TV is a Toshiba CT-90251 Purchased 2006
